Thread: What Tyre size?
Results 1 to 10 of 12
  1. What Tyre size?
    Aug 2007
    Hello everyone,
    my first post here. My wife has just bought a Golf 3 1.9 diesel; it came with aftermarket alloy wheels, 16". The tyres on it look awfully thin and small, they are 195/45 R16, and barely cover the rims. They look like they are due for replacement soon, but I wondered if I could go to 195/55 to fill out the wheel arches a bit more? Or is 45 the biggest section on a 16' rim?
    Many thanks
  2. Re: What Tyre size?
    Hi Mac
    Looking at the figures changing to a 195/55/16 will result in a change in the overall diameter of 6.8% the recommended maximum is +/- 2.5 %. Even changing to a 50 profile will result in a change 0f 3.8% which is again over the recommended intervals.
    Therefore I'm afraid you shouldnt do it.
    The only other option is to try and pick up a set of Original Equipment alloys or steel wheels for the car if you really don't like the alloys and tyres that are on it.
    If you do change the wheels make sure you remove the old spacers / distance pieces that may be fitted on the hubs.
    Hope that helps a bit
    Regards
    Richard
    ETYRES.co.uk
  3. Re: What Tyre size?
    Aug 2007
    thanks for the reply; I thought I might be able to increase the tyre size because the current tyres look smaller than the normal (ie original) tyres that I see on all other Golfs (and I don't mean people with 17" rims!!!); I just wanted to get back to the original tyre circumference. The current ones are deffo smaller than OEM.
  4. Re: What Tyre size?
    Canada
    does your car quote tyre pressures inside the fule flap, or door jam, should give yout the size of wheel and profile. don't worry if it doesn't quote the same size wheel.
    use this to calculate the change.
    http://www.alloywheels.com/TyreCalc.asp
  5. Re: What Tyre size?
    Aug 2007
    Good idea! I'll check it out tomorrow when it's light.
    Thanks.
  6. Re: What Tyre size?
    Mar 2007
    U-96
    Hi Richie,
    Aside from the obvious perils of speedo inaccuracies/under-reading, what are the issues of increasing the wheel/tyre diameters beyond +/- 2.5% ?
    Can any damage be done to the car, in particular to the diff or the gearbox ?
    TR7
  7. Re: What Tyre size?
    Mar 2007
    U-96
    Quote Originally Posted by RichieVWV6 View Post
    Hi Mac
    Mac,
    You could go for a set of 205/45/16s. These will provide you with an extra 9mm of comfort/tyre diameter over your current 195/45/16 setup, and provide a 2.3% diameter difference to a standard 185/60/14 Golf MK3 setup, which is within the permissible 2.5% Richie eluded to.
    The 205mm wheel will be 10mm wider, possibly providing better grip, but also more likely to tramline, i.e. the steering will have a tendency to follow any deviations/channels in the road.
    These are also a reasonably common size, being available on Goodyear F1s . However, this isn't a tyre comparison thread ...
    TR7
  8. Re: What Tyre size?
    TR7
    As rightly stated speedo will be affected.
    There is the possibility of driveshafts and gearing being affected, hence why the recommended difference is so small.
    But it is only a possibility, I personally do not know of anyone who has had any issues with being over the recommended guidelines though I would personally not risk it. (I have enough bad luck as it is without risking more lol)
    The only other thing to consider is of course whether the tyres (wider) have enough clearence to avoid suspension and springs etc to avoid rubbing or touching when the suspension bottoms out.
    I have seen loads of cars where this has destroyed tyres prematurely.
    Regards
    Richard
  9. Re: What Tyre size?
    neileg Guest
    I think the Mk3 looks 'underwheeled' on any of the standard wheels. So aftermarket fitments that keep the same rolling radius are going to look similar, the bigger the wheel diameter, the lower the tyre profile but the same overall size.
  10. Re: What Tyre size?
    Canada
    Regards
    Richard
    it not just the tyre that get destroyed the car can suffer to and in extreme cases the driver!!!
    It ok going for bigger wheels, tyre etc, but you need to adjust the suspension geometry to compensate or you will jsut wear the tyre out quicly or even ruin the handling. Bigger is not allways best
  1. passat estate 1.9 td 1994 correct tyre size
    By swonny2 in forum Passat - Archive Topics
    Last Post: 04-06-2007, 09:06 AM
  2. Wheel size and tyre fitment
    By chasw7 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-03-2007, 10:51 AM
  3. Maximum wheel/tyre size on A4?
    By Mark A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-03-2007, 10:58 PM
  4. Tyre size info
    By JustinM3 in forum Audi A4 - Archive Topics
    Last Post: 08-02-2007, 01:20 PM
  5. Passat tyre size
    By ImolaOrange in forum Passat - Archive Topics
    Last Post: 17-12-2006, 10:58 AM
