Thread: Interpret these DTCs plz
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Interpret these DTCs plz
    Canada
    Quote Originally Posted by Loofer View Post
    Well I finally I've finally got the registered/activated version of 409.1
    It manages to find more faults using AutoScan on with this version incl:
    Address 46: Central Conv.
    Controller: 1J0 959 799 AH
    Component: 2L Zentral-SG Komf. 0001
    Coding: 04097
    Shop #: WSC 00434
    2 Faults Found:
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    35-10 - - - Intermittent
    00944 - Heated Exterior Mirror: Passenger Side (Z5)
    35-00 - -
    A bit dunbious as I thought I didn't have Heated mirrors on mine. The switch is either L, R or 0. I thought the heated option had 0 replaced by a symbol similar to demisters.
    Finally, I was unable to 'Clear all DTCs'. Got a popup message saying 'Profssional Grade Interface required for this action'!!
    I'm a bit miffed after spending £50.
    The heated mirrors on mine switch on with the rear window. no heated symbol on the remote control button.
    Don't Ross tech discount what you've paid already if you buy the proper cable?
  2. Re: Interpret these DTCs plz
    Mar 2007
    Greater Manchester
    Quote Originally Posted by onzarob View Post
    The heated mirroe on mine switch on with the rear window. no heated symbol on the remote control button.
    It's a dumbe interface I bought from eshrules. But they do rebate £50 activation fee if you you upgrade to the new interface.
    I jus need to find out whats up with my mirrors now. RossWiki says:
    [edit]
    Possible Symptoms
    • Mirror Heating doesn't work
    [edit]
    Possible Causes
    • Wiring and/or connections faulty
    • Mirror Heating faulty
    [edit]
    Possible Solutions
    • Check if 12V on mirror connections is present
    • Replace Mirror (Z5)
    [edit]
    Special Notes
    • Sometimes the switch button for the mirror has 'L', 'R' and '0'. When switched on '0' the mirror heating is on!
    Don't want to be dismantling my mirrors now. Must be a central connection if both sides have registered fault codes
    2001 Bora TDi PD 115 (AJM)
  3. Re: Interpret these DTCs plz
    Canada
    I would check each miiror first, it a circuit on the back of each, and is know to fail, could easily have both out. In my audi book the control knob can be in any postion and not effect the heating of the mirrors.
    I think one guy on here mended the circuit on the back of a mirrot but i don't think they cost to much in the first place..
