Thread: oil leak at the top back of the AWX TDI engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. oil leak at the top back of the AWX TDI engine
    Jan 2011
    derby UK
    Beside the high feul consumptio issue I've also discovered the oil leak at the top back of the enginine head. Is that the vacuum pump? I just assumed before it's from EGR but
  2. Re: oil leak at the top back of the AWX TDI engine
    Mar 2013
    Brierley Hill
    Funny you should mention that..... it appears mine is wet there too..... I assumed EGR and will soon strip it off and replace any seals etc...
  3. Re: oil leak at the top back of the AWX TDI engine
    Jan 2011
    derby UK
    I wonder if this pump could somehow affect fuel comsumption. Low vacuum may fool ECU perhaps. I've got VCDS so wonder if I could check it in one of the blocks.
  4. Re: oil leak at the top back of the AWX TDI engine
    Mar 2013
    Brierley Hill
    I assume you are referring to the Tandem fuel / vacuum pump - honest answer is I'm out of my depth there..... My gut feeling is that it wouldn't be the issue as you would have braking and other issues also if that had failed. Hopefully someone like Crasher / Zollaf may come along and offer some knowledge......
  5. Re: oil leak at the top back of the AWX TDI engine
    Sep 2008
    chester
    17 Post(s)
    Could be diesel could be oil,check the bolts for tightness,unless its peeing out though I would think your poor fuel is something else,check the temp sensor.
  6. Re: oil leak at the top back of the AWX TDI engine
    Jan 2011
    derby UK
    temp sensor checked by VCDS. Sits on 90 C. I will change glow plugs to help short run diesel preheat. Like mentioned before it runs well
  7. Re: oil leak at the top back of the AWX TDI engine
    Mar 2013
    Brierley Hill
    If all else is well I would defo be taking a look at the timing and making sure its bang on.... as I said in my other post setting mine properly to spec has improved low down torque - although I haven't driven enough to check the new mpg....
    Pop the upper timing cover off and see if there are any tippex marks...
  8. Re: oil leak at the top back of the AWX TDI engine
    Feb 2013
    Swindon
    Seepage from air intake pipe/egr connections or cylinder head (rocker) cover gasket which run over the top of the tandem pump or as nevo says.
    A picture would be so helpful here, eh s66mjetdi!? Nice to hear you've got your timing sorted.
  9. Re: oil leak at the top back of the AWX TDI engine
    Jan 2009
    york
    ive got a small leak from the back but when I look the pipe coming out of the turbo is worn and is slightly loose I think a new pipe is in need !! and a new clip.
    Audi A4 1.9tdi 130 sport!! - stealth!!
  10. Re: oil leak at the top back of the AWX TDI engine
    Mar 2013
    Brierley Hill
    Pictures...... You say....gimme 5!
  1. Oil leak from 1.9TDI AWX engine
    By Adam Watson in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2012, 02:08 PM
  2. 2001 SE TDI 1900 AWX diesel-oil leak
    By Mamohau in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2011, 10:22 AM
  3. why oil leak from top of dipstick
    By tiredeyes69 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2011, 09:21 PM
  4. Please Help Oil leak on top of engine
    By skulz768 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2009, 10:50 PM
  5. Oil leak from top of turbo golf gt tdi 150
    By ian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2007, 11:04 AM
