Thread: hey guys new to forum and hope some one can help with my audi a4 not starting
Results 1 to 10 of 12
  1. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Aug 2011
    Meath
    Need to check induction system, vacuum pipes, air filter, fuel filter and first I'd check the EGR
  2. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Apr 2013
    portsmouth
    sorry for typing above i meant to say fuel filter not oil filter (found oil in oil filter so needed to change it lol)
    also i will recheck the egr again in lunch break tomorrow i think their is a actuator test on the scanner
    is their a manual way to test it ?
  3. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Aug 2011
    Meath
    Only the full version of VCDS can test actuator. Theonly manual test I know is "is it stuck"
  4. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Apr 2013
    portsmouth
    Quote Originally Posted by Doctle Odd View Post
    lol if you mean stuck closed and just clicking when ignition is switched on then possibly
    how does these egr work on diesels same as petrol ? open on cruse
    i will report my finding tomaro
    also is the fuel return supposed to be pressurized ?
    also the car runs on ether on the button
  5. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Aug 2011
    Meath
    STOP using ether! EGR in a diesel reduced the amount of oxygen getting into the engine and in doing so creates soot, carbon and other nasty stuff that jams valves and makes your car run badly, EGR Valve also worsens fuel consumption in a diesel, I don't think there's much pressure on the fuel return.
  6. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Apr 2013
    portsmouth
    nice wright up good explanation thanks for the info
  7. Re: hey guys new to forum and hope some one can help with my audi a4 not starting
    Apr 2013
    portsmouth
    Quote Originally Posted by imi View Post
    just a quick update i have gone back to basics testing the fuel system took single injector out at a time and check for fuel, then put back in and same to the next injector and so on, all are showing flow of fuel
    but even with the injector out with few cranks of engine the fuel filter return is pressured (defiantly is not normal)
    so i checked the running car and after a few cranks no pressure in return of fuel filter
    what i would like to no is is their a one way valve in the return pipe at some point
    my plans for tomara is to switch the tandem pump i am unsure of the used unit i have put on the engine it was one on the shelf i had,
    also i have diesel in sump
    injector seals are new
    is their anything else i should do at this point ?
  1. New to the Audi forum guys , just a quick hello
    By andytaylor1980 in forum New Member Introductions
    Last Post: 02-03-2013, 06:43 AM
  2. Hey hey hey, Ruscool here, I drive a vegitarian Audi 80 Avant
    By ruscool in forum New Member Introductions
    Last Post: 16-04-2012, 11:23 PM
  3. Hi guys. Soon to be an audi owner I hope
    By doublem_1 in forum New Member Introductions
    Last Post: 31-08-2010, 12:51 PM
  4. Hi, new to forum, hope you can help?
    By marco w in forum New Member Introductions
    Last Post: 04-01-2010, 09:12 PM
  5. Hey guys I've got my first Audi!!!!!
    By timmayaudi in forum New Member Introductions
    Last Post: 13-05-2008, 07:22 PM
