Thread: Auto Gearshifter Stuck In Park(p)
  1. Auto Gearshifter Stuck In Park(p)
    Aug 2007
    HI EVERYONE , I VE A PASSAT 1.9 TDI . (GEARSHIFTER/ LEVER/ STICK) STUCK IN PARK (P) AND DONT MOVE EVEN WHEN PRESSING THE BRAKE. IN MY KNOWLEGDE , WHEN YOU PRESS THE BRAKE , IT MAKE A CLICK SOUND WHICH ALLOWS TO SHIFT ON P R D ETC.... BUT NOW NO CLICK SOUND. SOMEBODY TOLD ME IT MIGHT BE SHIFT LOCK SOLENOID.. CAN ANYONE HELP PLEASE .. THANKS IN ADVANCE...............
  2. Re: Auto Gearshifter Stuck In Park(p)
    Jun 2006
    UK, Mids
    Does the light telling you to press the brake extinguish when you do? If not it is most likely the brake on off sensor that the pedal operates - irrespective of whether the brake lights work (two switches in one)
  3. Re: Auto Gearshifter Stuck In Park(p)
    Aug 2007
    the light stays on and doesnt swich off when pressing the brake .... where is the sensor suitated ?? and the brake lights still works fine when applying the brake.
  4. Re: Auto Gearshifter Stuck In Park(p)
    Jun 2006
    UK, Mids
    It is the brake light switch I'd say. It is above the pedal. If you find the pinouts, you could bypass it, but it is a 4 pin switch, and different pins get shorted whether the brake is up or down this is why the brake lights can still work. Of course it may not be this, but sounds like a likely culprit.
  5. Smile Re: Auto Gearshifter Stuck In Park(p)
    Aug 2007
    ...cheers mate for giving advice on it, as somebody told me i can bridge the connection too but do you know which wire to brigde ?!!!! and i will check it out and let you know mate thanks for your help
  1. Is it illegal to park in a turning bay?
    By marty72 in forum Chat - Completely Off Topic
    Last Post: 07-08-2007, 06:21 PM
  2. jetta tdi auto trans stuck? (bora uk)
    By riebs in forum Bora - 1998 - 2005
    Last Post: 03-06-2007, 07:37 PM
  3. A6 CVT Drive Park N lights all on.
    By RichardB in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-03-2007, 06:02 PM
  4. Passat auto gets stuck in low gear!
    By vw18estate in forum Archive posts
    Last Post: 21-02-2007, 06:48 PM
  5. passat tdi auto box stuck in third
    By keefyc in forum Archive posts
    Last Post: 26-12-2006, 08:49 PM
