Thread: Adaptive lights
Results 11 to 20 of 33
  1. Re: Adaptive lights
    Mar 2013
    Windsor
    Hi, Ive sent you an email.
    I've looked at the link for removal of the sensor, but does anyone know where the sensor I cant seem to find it for looking
  2. Re: Adaptive lights
    Sep 2011
    Lurking over a keyboard ...
    In the instruction "plenum chamber"...
    Video courtesy of Royclark ...
    The video is in context of the drains (Link:- https://www.vwaudiforum.co.uk/forum/s...844#post797844) ... the air con intake is the black unit in the centre...
    Will email you stuff later, gotta go do some work ...
  3. Re: Adaptive lights
    Mar 2013
    Windsor
    Thanks for that, but i still cant see the sensor, i know im a n00b. does anybody have a picture of the sensor/where it lives?
  4. Re: Adaptive lights
    Sep 2011
    Item 4 in this image Link:- Water deflector rain channel water drain valve sensor for air quality. Fits: 2006 Audi A6 | Jim Ellis Audi Parts
    Also see the links in post 8
    Quote Originally Posted by gupsterg View Post
    RE G238 Link:- Function Link:- Measuring blocks for use with VCDS
    P/N 4B0 907 659 A approx. £75 inc vat ... please verify with local dealer...
  5. Re: Adaptive lights
    Mar 2013
    Windsor
    Legend.
    From that diagram it looks like its close to the two little valves on close to the passegener's side? Looks nothing like the part that ive ordered though
  6. Re: Adaptive lights
    Sep 2011
    There was a typo I typed 4B0 907 G59 A when it should be 4B0 907 659 A
    Here is an ebay link to show what they look like... Link:- 4B0907659A | eBay
    I would buy new only...
    AFAIK my car has one so will check for you ...
  7. Re: Adaptive lights
    #17
    Sep 2008
    mostly in the garage
    Note that although there is a fault recorded for the air quality sensor it won't be related to the symptoms you have of one vent always blowing hot. It's only for automatic operation of recirculation mode. As such you may not want to bother with it or it could be a dodgy connection.
    Usually the hot vent is an issue with a blend motor (although you have no fault code) or flap.
    1 1 0
  8. Re: Adaptive lights
    #18
    Mar 2013
    Windsor
    Thank you, any luck on emailing that info?
  9. Re: Adaptive lights
    #19
    Mar 2013
    Windsor
    I've bought the sensor now
    suppose I'll change it anyway, you know of anyway to test the flap ect? thanks
  10. Re: Adaptive lights
    #20
    Sep 2008
    have a look with vcds in address 08, there should be some measured value blocks to read/compare requested and actual values etc and also basic settings for calibration.
    1 1 0
  1. Adaptive Brake Lights
    By jallan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-11-2012, 01:43 PM
  2. Question xenon adaptive lights & foreign travel
    By HenryB in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-01-2010, 11:59 AM
  3. Question Adaptive lights
    By PerryGarrod in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-10-2009, 06:57 PM
  4. Question adaptive lights
    By oldgrowler in forum A8 - S8 - V8
    Last Post: 14-09-2009, 11:44 PM
  5. Question Headlight washer/adaptive lights
    By OoIANoO in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 09-01-2009, 12:33 PM
