Thread: Limp Mode Code PO299 HELP!!
Results 1 to 8 of 8
  1. Limp Mode Code PO299 HELP!!
    Apr 2013
    Bulford, Wiltshire
    Hi guys, just new to this.
    I was driving from North Yorkshire today backmto Bulford Camp and my VW Passat 2009 2.0TDI 170 BHP lost power, heater plug lamp started to flash and I was getting reduced throttle.
    I pulled into services and called my breakdown service, he checked it and the code that came up was PO299 TurboCharger/ underboost.
    Just want to know what this problem is?. Is it common and where do I need to start checking.
    Many thanks for any help on this matter.
    Kelv
  2. Re: Limp Mode Code PO299 HELP!!
    46 Post(s)
    16683/P0299/000665 - Ross-Tech Wiki
    explanation of said fault
  3. Re: Limp Mode Code PO299 HELP!!
    Norfolk
    Quote Originally Posted by Kelv634 View Post
    Kelv
    It helps if you say what engine. I assume it's a common rail. The boost actuator has probably failed. VW charge about £250 to supply and fit a new one. It's a common fault.
  4. Re: Limp Mode Code PO299 HELP!!
    Apr 2013
    Bulford, Wiltshire
    Martin, thanks for the help mate, its a 2009 2.0 TDI 170 Hp
  5. Re: Limp Mode Code PO299 HELP!!
    Apr 2013
    Bulford, Wiltshire
    Martin, just checked engine and it is :
    3c51x2
    Chassis No:
    wvwzzz3cz9e135387.
    Kelv
  6. Re: Limp Mode Code PO299 HELP!!
    Apr 2013
    Bulford, Wiltshire
    Martin, where is said Boost Actuator located mate?.
    Many thanks.
    Kelv
  7. Re: Limp Mode Code PO299 HELP!!
    Norfolk
    Many thanks.
    Kelv
    What engine code do you have. Actuator is part of turbo. If your engine is a common rail it will be a black lump with some wires connected to it. Search the forum. A member put up pics of his in the last few weeks.
  8. Re: Limp Mode Code PO299 HELP!!
    Apr 2013
    Bulford, Wiltshire
    Martin,
    Many thanks for youre help, I have checked the Actuatot today and when I sucked on the hose going into it, it wasnt holding, bought a nerw one from VW £118 and that one is so that is my job tomorrow.
    Another question, what is the interval for my timing belt change
    Eng NO 3c51x2
    Chassis No:
    wvwzzz3cz9e135387.
  1. Replies: 5
    Last Post: 07-02-2013, 06:52 PM
  2. "Limp Mode" - Audi A4 2002 2.0 Sport in Shoutdown Mode
    By ARJ230580 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-09-2012, 11:14 PM
  3. fault code and limp home mode
    By kstead in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-09-2010, 07:54 PM
  4. Question Limp mode/safe mode
    By fourringsrus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 02:06 PM
  5. A4 Goes into limp mode Vag code is
    By diode in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2008, 10:15 PM
