Thread: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
Results 1 to 10 of 10
  1. Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Apr 2013
    Lancaster
    Hi Guys,
    I have had my Passat for nearly a year and have not got to the bottom of this problem yet. A friend has just scanned the car for me and below are the results. I have replaced the Boost pressure sensor and parking brake button in the last couple of weeks.
    It will sometimes go for weeks without a problem, then it will either go into limp mode randomly while driving - or sometimes start up in limp more. If you restart the car it usually comes back out of limp mode.
    Thanks in advance for any help!
    Ben
    Monday,01,April,2013,16:42:43:16641
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72 7D
    VIN: Mileage: 184630km/114723miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    69-Trailer -- Status: Not registered 0001
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BKP.clb
    Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
    Component: R4 2.0l PPD1.5 9970
    Revision: --H05--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00659 210 999999
    VCID: 69D34F894038E35096B
    3 Faults Found:
    18000 - Altitude Sensor / Boost Pressure Sensor
    P1592 - 006 - Implausible Correlation - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 5
    Reset counter: 233
    Mileage: 184475 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:56:00
    Freeze Frame:
    RPM: 0 /min
    Text: 0 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 11.41 V
    Text: 998 hPa
    Text: 2484 hPa
    16622 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 006 - Signal too High - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 234
    Mileage: 184482 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:34:23
    Freeze Frame:
    RPM: 0 /min
    Text: 0 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 11.19 V
    Text: 0 hPa
    Text: 2993 hPa
    16610 - Throttle Pedal Position Sensor (G79)
    P0226 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 184256 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:52:09
    Freeze Frame:
    RPM: 1568 /min
    Text: 0 Nm
    Speed: 82.0 km/h
    Text: 0.4 %
    Voltage: 14.58 V
    Text: 1.13 V
    Text: 0.45 V
    Readiness: N/A
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0658608070
    Coding: 0013602
    Shop #: WSC 00028 028 00001
    VCID: 2F67E191BE5C4D6088F
    No fault code found.
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA
    Component: ClimatronicPQ46 050 0404
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 60C552ADB302A218415
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000003731944
    Coding: E1800F0700041A00000A00000F00000000085D435C0000
    VCID: 3065E2EDA3625298915
    Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer VW461 012 0503
    Coding: 00065493
    Shop #: WSC 00028
    Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 011 1110
    Coding: 00208933
    Shop #: WSC 00028
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 05 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PS7UB4Y
    Coding: 0012341
    VCID: 2D5BFB99B4503F70BA3
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenksäulenmodul 005 0010
    Revision: 00005000 Serial number: 3C5953507A
    Coding: 0000003
    VCID: 2A51F08585BE28485F1
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 H HW: 3C0 920 960 H
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0014000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 01234 512 00000
    VCID: 28550A8D9BB21A58495
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 218
    Reset counter: 236
    Mileage: 170608 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:43:19
    Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C05C24010A
    Coding: 3DFD2C04C21003
    VCID: 214317A9F888EB100EB
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 248
    Mileage: 168271 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:22:20
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
    Component: IMMO 038 0367
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3261E8E5AD6E6088E71
    Part No: 3C0 905 861 D
    Component: ELV 024 0370
    3C0905861D ELV 024 0370
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2366
    Coding: 0000693
    VCID: 3669D4F541067CA8CB9
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 346DEEFD577A6EB8F5D
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 038 0455
    Coding: 01910A0801860E763804941570085FCE103C80
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Component: Innenraumueberw.002 0508
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000692
    VCID: 3777D9F1460C85A0D0F
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000011
    1 Fault Found:
    02443 - Control Head
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 9
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.42 V
    Count: 40
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 P
    Component: Radio GR0 015 0019
    Revision: 0001503S Serial number: VWZ2Z2E3387054
    Coding: 0040400
    VCID: 336FEDE152746980EC7
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    Address 69: Trailer
    Cannot be reached
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
  2. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Norfolk
    You need to clear everything. Go for at least 4 drives (ignition on-drive-ignition off). and then scan again. Otherwise you don't know which faults are current or just old stored faults.
  3. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    DSG4ME Guest
    I'd suspect the turbo veins being stuck will be your eventual culprit if it happens when you either flat out it off the line or it goes limp trying to gun it at speed.
  4. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Apr 2013
    Lancaster
    Ok, I have reset all the fault codes and been out for a drive, I pulled over 5 or 6 times and turned off the ignition - then started and set off again. (Car went into limp mode about 400 yards from home), then was fine after the next time I stopped/re-started.
    Here are the results after the drive:
    Tuesday,02,April,2013,17:30:02:16641
    Chassis Type: 3C0
    VIN: WVWZZZ3CZ6P154785 Mileage: 184640km/114729miles
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    Coding: 0000072
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00010001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 184643 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:22:56
    Freeze Frame:
    RPM: 0 /min
    Text: 0 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 12.20 V
    Text: 998 hPa
    Text: 1146 hPa
    Readiness: N/A
    Coding: 0013602
    Coding: 00065493
    Shop #: WSC 00028
    Coding: 00208933
    Shop #: WSC 00028
    Coding: 0012341
    Coding: 0000003
    Coding: 0007405
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 184643 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:27:18
    Coding: 0000693
    Coding: 0000692
    Revision: 013
    Coding: 0000011
    Coding: 0040400
    Coding: 0000144
    Address 69: Trailer
    Cannot be reached
    Coding: 0000144
    Thanks again for the help so far!
  5. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    46 Post(s)
    Go into your CAN gateway and untick the trailer module as its not present
    that will clear 69 and 19.
    engine fault is P1592 which relates to 18000/P1592/005522 - Ross-Tech Wiki
  6. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Norfolk
    1 Fault Found:
    This one can be a pain. Every time you start the engine the ecu is checking the boost pressure sensor against the atmospheric pressure (altitude) sensor. They must match. Yours don't match hence the fault code. With luck you need a new boost sensor. Keep your fingers crossed because you don't want a faulty atmospheric pressure sensor.
  7. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Apr 2013
    Lancaster
    Thanks guys, I have just replaced the boost sensor on the main intercooler pipe - is this the one you mean?
    Thanks again
  8. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Norfolk
    Quote Originally Posted by slingshot1801 View Post
    Thanks again
    Yes. With luck, that should fix things.
  9. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Apr 2013
    Lancaster
    Quote Originally Posted by martin1810 View Post
    I replaced that about a week ago, but still no different. What would you try next? Any idea on the part number and location of the atmospheric pressure sensor?
  10. Re: Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    Norfolk
    There isn't a replaceable atmospheric pressure sensor. It's built into the ecu. I would start looking for damaged wiring. You may have to check and clean the ecu pins or get someone to do it for you. Lets hope it isn't a sensor failure. To be fair, it usually isn't.
  1. Full scan results
    By PETER G in forum VCDS - Help Requests
    Last Post: 01-01-2012, 06:04 PM
  2. Please Help 110 tdi 1999 passat limp mode
    By tmanb5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2011, 07:31 PM
  3. Audi A4 limp mode VAG scan
    By cameronmk2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-06-2010, 11:57 AM
  4. Tdi limp mode/N75 problem?
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2008, 09:09 AM
  5. Passat TDI limp mode
    By ianocal in forum Passat - Archive Topics
    Last Post: 22-04-2007, 12:24 PM
