Thread: Steering Colum Fault
  1. Steering Colum Fault
    Jan 2013
    newcastle upon tyne
    firstly let me say hello, i'm a new boy. I'm after some help as the title suggests, late last night i put the key fob in the ignition of my 05 passat SE and nothing happened except an amber steering wheel lit up on the dash. Ive researched and discovered that its a steering colum issue nothing new it would appear, but thats not my problem, the car was booked into the garage and was due to be fixed today. But being a none car fella I booked a transporter to take my car to the garage, my car has an electronic handbreak that i cant disengage to get the car on the truck, that cost me £30.00 call out fee to learn that. Anyway I guess my question is how do i get the handbreak to release while the car is in imobilizied mode, Ive spoke the garage today that said that disconnect the battery for a bit, then re connect it, put the key fob in the car to turn the ignition on, then put the headlights on full beam while putting my foot on the brake and then keep pressing the the electric brake. Im a patient fella but ive been on this all day with no luck. I would really appreciate it if anybody can give me any other ideas or point me to some links, am i doing the sequence right i just dont know.
    Cheers for any help
  2. Re: Steering Colum Fault
    Norfolk
    You need some torx bits. Take off epb motor (two bolts) Wind caliper center drive back 360 degrees. Refit epb motor. Repeat for other side. Don't disconnect any wiring. The brakes are now free.
  1. Please Help Steering column fault??? Is this a recall?
    By blackdubbin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 02:09 AM
  2. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  3. Please Help steering warning fault
    By dido in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-08-2010, 07:42 AM
  4. Question Power Steering Fault
    By Witty in forum Ibiza - Cordoba
    Last Post: 12-12-2009, 10:47 PM
  5. Passat steering fault
    By kington in forum New Member Introductions
    Last Post: 24-06-2009, 10:59 PM
