Thread: 3.0 tdi hunting overrun
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
  1. 3.0 tdi hunting overrun
    8 Post(s)
    Hi all,
    I changed my car back to a 3.0 tdi two weeks ago, it's the 233 engine 171kw, Auto box and quattro 100k miles.
    It had quite a few dtc's which have now been sorted, including glow plugs and inlet manifolds low limit.
    After I changed the inlet manifolds I was hoping the MPG would improve, i'm barely able to get mid 30's at 70 mph, my earlier 165kw would do 40mpg at the same speed, I though the 171kw was a more economical engine.
    I also have an issue with the revs hunting/surging on overrun, if I'm driving at between 25-55 mph and come off the power to come to a junction etc the revs jump up and down around 300 rpm every second and you can feel the car jerking at the same time.
    The only fault left on the car is the drivers side enigne mount has a fault I can't clear and the drivers side electric heated mirror showing as open to ground.
    Any body any idea's on where to start looking? MAF, throttle body?
    I can post the dtc's later.
    Other than that I'm happy with the car
    Paul
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  2. Re: 3.0 tdi hunting overrun
    Jun 2009
    Bexleyheath, England
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  3. Re: 3.0 tdi hunting overrun
    8 Post(s)
    Thanks, I've already spent quite some time reading the whole thread, mine doesn't hunt at all on tickover, thats rock steady, only on the overun, I haven't had any luck in finding anything other than tickover hunting on the forums.
  4. Re: 3.0 tdi hunting overrun
    Sep 2007
    Bookham, Surrey
    Hi, I've got the same setup. Rarely got more than 33mpg on the motorway. Interestingly I think the mpg got better at about 85mph. The engine seemed to be just getting into its stride.
    On the overrun, on mine the revs jump about a bit when I take my foot off the gas around 40mph in 3rd or 4th. I think it's the torque converter getting a bit indecisive. I don't think it's the throttle making it rev, it's like in a manual when you feather the clutch and bring in the engine braking. Is that the same thing you're seeing??
    1 0 1
  5. Re: 3.0 tdi hunting overrun
    8 Post(s)
    yes that sounds like it's the same thing. Even if i just keep on the throttle a little i get no variation in revs, hopefully it's something i will get used to. It didn't do it on the test drive, typical!
    On the mpg side i've turned off my aux heater and mfa shown 39.7 for journey yesterday, it did go upto 43.4 so i'm hoping thats better.
  6. Re: 3.0 tdi hunting overrun
    Nov 2012
    Australia, Melbourne
    Hi, i've got the same thing happening to mine. I thought my gearbox was stuffed up. After taking it to Audi for a service they told me its the pulsation dampener thats causing it. Which would cost around $200 including hands.
    I haven't taken it yet. I will when i go in to change the front brake pads. So i don't know if it will cure that rev fluctuation while decelerating... Good luck.
  7. Re: 3.0 tdi hunting overrun
    Sep 2007
    Bookham, Surrey
    Aw crap - not another thing that might be wrong. This is my first auto - only driven manuals until I got this one. Thought it was a bit odd when I first experienced it but thought it was just one of those things with an auto. I've had it 3years now and gearbox is still silky smooth otherwise (other than the occasional lumpy downshift - usually to 2nd when i give it a bit of throttle just as its changing).
    So what's a pulsation damper??
  8. Re: 3.0 tdi hunting overrun
    Nov 2012
    The person questioned knows nothing more than the person questioning... lol
    No idea mate. If i get it fixed eventually ill update this forum with it.
  9. Re: 3.0 tdi hunting overrun
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by TheMatador View Post
    Link:- http://en.wikipedia.org/wiki/Harmonic_balancer
    1 1 0
  10. Re: 3.0 tdi hunting overrun
    8 Post(s)
    I did read yesterday, but now i can't find the link again, that the pulsation dampener can give upto 10% better mpg, my mfa is not reading near the correct value, as it's based on fuel pressure and the pulsation dampener controls the pressure, i'm thinking it maybe the answer.
    I will look on ETKA when i get back from easter and see if I can find it.
    I know I can adjust the mfa reading from vag-com but as I've ordered a bluefin also i dont want to start messing until everything is bedded down.
    PS Happy Easter all!!
  1. BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    By gupsterg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-09-2020, 07:48 PM
  2. 08 Golf TDI - Hunting idle
    By Blee36 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-01-2013, 11:24 PM
  3. Please Help golf mk3v 1.9 tdi 1993 hunting at idle
    By racin snake in forum Golf MK3 - 1993 - 1999
    Last Post: 28-11-2008, 08:21 PM
  4. 2000 TDi SE Tiptronic intermittent hunting
    By Audidothat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 02:43 PM
  5. Juddering on overrun
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 09:39 PM
