Thread: golf 4 1.6 16 v
Results 1 to 8 of 8
  1. golf 4 1.6 16 v
    Mar 2013
    albania
    hi.i have a vw golf 1.6 16v 2002 azd motor.my problem is that the motor spent to much oil.it spend 1l oil for 1000 km.what i should do ihave used all types of oils and no result.i have cleaned the breather pipe,the same result
  2. Re: golf 4 1.6 16 v
    Aug 2011
    Meath
    These engines do use some oil but that seems a little high. Is it leaking or burning oil?
  3. Re: golf 4 1.6 16 v
    Mar 2013
    albania
    it burn one liter oil for 1000km.it has no leaking.
  4. Re: golf 4 1.6 16 v
    Aug 2011
    Meath
    Any smoke? Is there high mileage?
  5. Re: golf 4 1.6 16 v
    Mar 2013
    albania
    no smoke.but i think is the high mileage.i wont to repair the motor,change all the parts needed.what do you think or should i buy a used motor.
  6. Re: golf 4 1.6 16 v
    Aug 2011
    Meath
    If the engine is ok you might try a rebore and a new set of rings and valve seals, a new engine wouldn't be cheap and unless you buy reconditioned I don't think it would be a viable option. Would you do the work yourself? A cheap known good engine maybe from a crashed car would be good if you could get one.
  7. Re: golf 4 1.6 16 v
    Feb 2014
    Luxembourg, Luxembourg
    I would also say to check the oil breather system, since it tends to get clogged and/or deteriorates and malfunctions. I have a 1.6sr with more than 300.000km which was consuming oil (no blue smoke, nothing). I cleaned and replaced one part on the oil breather system and the oil consumption completely disappeared. It is running relatively short runs everyday, which is the worst conditions for oil consumption and I do not add any oil between changes (10.000km).
  8. Re: golf 4 1.6 16 v
    Mar 2013
    albania
    i have cleaned the breather system.i changed set of rings,16 valveseals,16 guide valves.new oil.now the car is ok.i have made 15.000 km 0 consuption oil.
  1. Replies: 4
    Last Post: 18-01-2011, 09:03 AM
  2. Question Golf Mk3 Crank Possition Sensor Golf Mk 3
    By mustanguy600 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 10:35 PM
  3. GET YOUR GOLF ON TV - Used Car Of The Year Awards, IS YOUR GOLF THE BEST? PLEASE READ!!
    By Daisybeck in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-08-2007, 11:15 PM
  4. GOLF GTI EDITION 30 STUDY UNVEILED ON GOLF RECORD DAY
    Last Post: 24-06-2006, 08:02 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
