Thread: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
Results 1 to 10 of 13
  1. A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Oct 2012
    Birmingham
    Hi guys,
    It seems that my beloved car developed today, out of nowhere a problem.
    This morning I left to work at about 9 o'clock and as you know, the snow in Bham is about 5-10 cm tall on the side streets. I managed to get out without any help and got to work in no time. Did not have any problems.
    I parked and I have put the parking break on and left the car for 9 hours there.
    When I got back, I have put the ignition (low fuel beep), fastened the seat belt started the engine and released the parking break(with the foot on the break). The pedal became softer and I started driving. After 300m, I picked up some speed and a huge rattle started. I stopped and cleared all the snow blocking the wheel arches.
    Started driving again, same problem... I stopped at the gas station, inflated the tyres and left. The same rattle, very loud and it moves the entire car.
    When I accelerate you barely feel it, but when I reach 30-35mph and stop accelerating the rattle and the sound becomes very loud.
    I stopped in front of the house and took one of my mates for a drive, maybe if he hears it, he might have a clue.
    Followed the same procedure at starting the car, same rattle. I got to the petrol station again, looked at the arches, did some more cleaning, the suspension seems fine.
    The petrol station is uphill and I was concerned with the problem, started the car, moved 20m, I had to brake to give way and forgot to press the clutch and engine died.
    I started it up again and I got the ESP error, followed by a short 2 second Electronic Parking Break error (it was the parking break sign and 2 lightnings on the side) and both disappeared.
    I tried going backwards, the same problem. When I was coming back home, I accelerated to 40mph and the car was taking the corner to the left all by herself.
    Parked the car, fired the laptop, started reading the forum... EPB might be stuck. Can be unstuck by applying the EPB while moving.
    Got back to the car, started moving, pulled the handbrake the car stopped in a couple of meters, doing the annoying beep. Did this a couple of times, it still rattles.
    I looked at this video: Electro-Mechanical Parking Brake (EPB), rear brake pad service - YouTube and it looks like a tricky job, but the worst part is Monday I have to go to London.
    Now I have parked it on another street without the handbrake, just left in 1st gear.
    I know it's a long post, but I am a noob and I try to be as explicit as possible.
    Do you have any ideas guys? What can I do?
    PLEASE HELP me!
  2. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    46 Post(s)
    You definitely need a fault code scan.
    Paul Barls is in Birmingham and is a regular member - https://www.vwaudiforum.co.uk/forum/m...154-Paul-Barls
  3. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Oct 2012
    Birmingham
    I have sent a private message to Pigeon,tsunami and Paul, maybe one of them can help me, it looks like they live in birmingham, pretty close to me (don't want to risk bending the pads)
    Thanks Chris for the fast response. If anyone had a similar problem and have any ideas, please let me know!
  4. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Dec 2010
    Birmingham
    I will read the codes this evening so they can be posted here.
    Quote Originally Posted by Big.B View Post
    Now I have - 2014 Audi A6 3.0 TDI V6 Quattro S-Line (Silver)
    Previously 2012 Audi A8L 3.0 TDI Quattro SE Executive (Silver)
    2012 Audi A5 2.0 TDI S Line (White), and 2006 Audi A6 3.0 TDI V6 Quattro S Line (Black)
    Have VCDS 17+ (VAG-COM Diagnostic System) with HEX-USB+CAN Interface & old style interfaces.
    1 1 0
  5. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Oct 2012
    Birmingham
    I Want to thank Paul for driving to my house and reading the fault codes. Great guy, cheers mate!
    After he left, went for a test drive, same problems.
    He did not erase the fault codes, so I still have them on the computer.
    I have deleted the No Fault ones, left just the problems...
    If anyone can help, that would be greatly appreciated!
    Here they are:
    Sunday,24,March,2013,20:01:57:05809
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 4F0
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
    62 72 76 77
    VIN: Mileage: 229260km/142455miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H05 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020855
    Shop #: WSC 02325 785 00200
    VCID: 2C5DF6828F1D8678AD4
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 144
    Mileage: 229264 km
    Time Indication: 0
    Date: 2013.03.23
    Time: 19:27:40
    Freeze Frame:
    Hex Value: 0x0100
    Hex Value: 0x4012
    Hex Value: 0x0003
    Hex Value: 0x1661
    Hex Value: 0x00FF
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8095053
    Shop #: WSC 00000 000 00000
    VCID: 1C3D2642DFBD76F8DD4
    1 Fault Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 237
    Mileage: 220880 km
    Time Indication: 0
    Date: 2012.12.14
    Time: 20:21:19
    Freeze Frame:
    Text: 00000000
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01012348000000
    Coding: 0000251
    Shop #: WSC 02335 785 00200
    VCID: 2E59FC8AB901F468830
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    2 Faults Found:
    01503 - Bulb for 3rd Brake Light (M25)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 120
    Mileage: 228897 km
    Time Indication: 0
    Date: 2013.02.23
    Time: 17:56:43
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 118
    Mileage: 229015 km
    Time Indication: 0
    Date: 2013.03.05
    Time: 20:09:55
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB CA3C0040 H03 0040
    Revision: --H03---
    Coding: 0000111
    Shop #: WSC 00000 785 00200
    VCID: 1E392C4AC9A164E8330
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 144
    Mileage: 229264 km
    Time Indication: 0
    Date: 2013.03.23
    Time: 19:27:45
    Freeze Frame:
    Voltage: 12.53 V
    Count: 236
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000009814
    Shop #: WSC 00502 210 01778
    VCID: 234F1DBEE2C349001CE
    Subsystem 1 - Part No: 4F0 915 105 C
    Component: von VA0 1603300617
    Coding: 344630393135313035432056413031363033333030363137
    Shop #: WSC 00000 512 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 14
    Mileage: 224540 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:02:14
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 6
    Mileage: 224544 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:27:31
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Mileage: 224544 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:27:41
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Mileage: 224544 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:27:51
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 224544 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 09:28:01
  6. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    46 Post(s)
    Okay you seem to have a brake light out (high one), a failing battery, something wrong with your CD player, a failing alarm horn and obviously the handbrake problem.
    00532 - Ross-Tech Wiki
    As the error only appears in the handbrake When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
  7. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Sep 2011
    Lurking over a keyboard ...
    I don't think your CD/media player has anything wrong... that is just a media error... ie disc had a read error... its an old fault, fault frequency (occurrence) only 2...
    Your battery IMO would need further checks to say failing... all the battery faults are happening on same day (31/12/2012), looking at the time stamps a drain must have been happening at that time and the battery regulation module started intervening... perhaps you were using electrical items without engine running? did that battery low sign come up in DIS?
    As to bulb (M25), time stamp old (Date: 2013.02.23) Fault Frequency: 2... fault says an intermittent fault perhaps a connection loose?
    Your alarm horn only 1 fault frequency... like fault says an intermittent fault.... time stamp = Date: 2013.03.05 Time: 20:09:55
    These are the two things which IMO are related to your current issue...
    Coding: 0020855
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 144
    Mileage: 229264 km
    Time Indication: 0
    Date: 2013.03.23
    Time: 19:27:40
    Freeze Frame:
    Hex Value: 0x0100
    Hex Value: 0x4012
    Hex Value: 0x0003
    Hex Value: 0x1661
    Hex Value: 0x00FF
    Revision: --H03---
    Coding: 0000111
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 144
    Mileage: 229264 km
    Time Indication: 0
    Date: 2013.03.23
    Time: 19:27:45
    Freeze Frame:
    Voltage: 12.53 V
    Count: 236
    There is a thread which may have info will have a nose at it to see what it says... perhaps the original poster of that may see yours and chime in or another comment...
    ATB
    G
  8. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Oct 2012
    Birmingham
    I remember the battery problem on the 31/12, but I think it's fixed now as I did not have such issues since.
    It's still the same problem with the brakes or whatever is happening: when driving, I can hear a lot of noise from the back, it's still pulling to the left.
    Last night after Paul came by and read the codes, I followed a friend's advice and put some hot water on all 4 wheels, but no luck.
    I will call the RAC tomorrow and see how it goes. The only mystery for me is: in the morning it had no problems, when I left work in the evening sounded like the entire back part was ripped apart and put back with duck tape.
    Thank you guys for the help, but before I work on the break lights or see what's wrong with the battery, I need to get this fixed.
  9. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Sep 2011
    The thread I thought which may help is not the same fault as yours ...
    Did a bit of googling for "ABS Brakes 00532 - Supply Voltage B+" ... varied posts/info, some read it could be a corroded fuse, malfunctioning relay, etc,etc... you'd need to check things like that... as faults says 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent its a lack of voltage its detecting IMO...
    Module 03: ABS Brakes is logging fault first... module 53: Parking Brake is registering fault after, going by the time stamps...
    So going by how you say car pulling to the left have you jacked up car and checked if wheels are locking? even without jacking up discs must be hotter on side which locking occurring...
    Try a PM to A8 Tech... sorry no more info ...
  10. Re: A6 C6 Electronic Parking Brake (EPB) Problem, please help!
    Oct 2012
    Birmingham
    There is no fault on the car...
    They tried to steal my wheels, took down all the bolts, got to the locking one, could not open it, so they left with 1 bold and did not screw the rest back, just gave them a few twists. They tried it on all 4 of them, so that is why the entire car was shaking and pulling to the left.
    Lucky me, there's no problem with the breaks, but I am worried of what could have happened if the wheels came off while I was driving as they were hold securely only in 1 bolt.
    That day I parked on Broad Street, one of the main roads in Birmingham City Center.
    Would you advise me to call the police, maybe they have cameras in that area?
    Anyway, thank you very much: Gupsterg, Chris, Paul !
    1 1 0
  1. Electronic Parking Brake Fault Problem
    By doriclad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-11-2016, 07:09 AM
  2. electronic parking brake again :-(
    By shropslad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2012, 09:00 PM
  3. Please Help Electronic parking brake
    By chapel1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2011, 07:28 PM
  4. Question Electronic Parking Brake
    By airspark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2011, 09:13 PM
  5. Electronic Parking Brake
    By ondines_curse in forum Scirocco - 2008-
    Last Post: 19-09-2008, 09:55 PM
