Thread: PD 130 manual 32mpg :(
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 69
  1. Re: PD 130 manual 32mpg :(
    #31
    Mar 2013
    Brierley Hill
    I'm led to understand 0-0 - 0.5 is ideal.....
  2. Re: PD 130 manual 32mpg :(
    #32
    Jan 2011
    derby UK
    I have seen that too. It claims that 0.5 to 1.0 is best. If someone can confirm that value I've listed is timing I should be able to try to turn in unticlockwise a bit.
  3. Re: PD 130 manual 32mpg :(
    #33
    Mar 2013
    Brierley Hill
    This I need to sort out.......
  4. Re: PD 130 manual 32mpg :(
    #34
    Feb 2013
    Swindon
    Quote Originally Posted by S66MJETDI View Post
    Removing the cat removes restriction in flow - therefore reduces back pressure ?
    Yep, you're right but it still increases stress on turbo shaft apparently by spinning up too quick
  5. Re: PD 130 manual 32mpg :(
    #35
    Mar 2013
    Brierley Hill
    Quote Originally Posted by ajrayner View Post
    Seems like a damn fine excuse for a more beefy turbo...... once my niggles are sorted out the old girl will be receiving a mild remap .... So it wont hurt.... I hear there are a few of the 170bhp rated 2.0tdi's that bolt straight on, I assume these may be a little stronger, can anyone confirm?
  6. Re: PD 130 manual 32mpg :(
    #36
    Feb 2013
    Swindon
    Google44
    Monitoring synchro angle at idle is sufficient...ideally 0 but you can always monitor the fuel consumption (also in engine measuring blocks in VCDS) at idle with any adjustments you make to find your "sweet spot".
    A mass of numbers from a log is difficult for anyone to read. Check out this site for tips on how to turn the data into more useful graphs and also excellent gen regards engine health checking using VCDS. It's a passat website but it's the same 1.9 PD engine in our Audis
  7. Re: PD 130 manual 32mpg :(
    #37
    Mar 2013
    Brierley Hill
    Just to add to my suspicion that my mpg issue was poor timing . Over the last few days I have ratcheted up 47 miles since reseting the timing..... every time I get in the car now it seems smother and more powerful like the ecu is readjusting something or something is clearing...... Is there a rational explanation for this - would the ecu be relearning or is it not that bright on this age of car?
  8. Re: PD 130 manual 32mpg :(
    #38
    Feb 2013
    Swindon
    In a nutshell, if the timing is out then fuel is injected into the cylinder at a point where the piston is not in the optimum position to generate maximum driving force on the crankshaft for that given squirt of fuel. The result of this is a reduction in torque (moving force) for the fuel squirt amount. The ecu can compensate for this mismatch to a certain degree by delaying/advancing the fuel squirt. It can only do so much though and is no substitute for mechanical harmony between cam and crank ie fuel squirt happens when piston is at maximum extension. This leaves to ecu to concentrate on providing the drivers wish map effectively ie throttle pedal position.
    Not an experts explanation but hopefully it makes some sense!? If you really want the juicy details the checkout this bedtime reading.
  9. Re: PD 130 manual 32mpg :(
    #39
    Mar 2013
    Brierley Hill
    Lol I'm familiar with the static burn rates of fuel at different temps and the constant need to adjust injection timing to compensate for the dynamic changes in the speed of the piston stroke...... just wondered if the ECU's in our cars were advanced enough to relearn optimum settings in relation to static engine settings. ( I spent many years repairing jet aircraft engines...... slightly different in operation but many of the principles still hold.)
  10. Re: PD 130 manual 32mpg :(
    #40
    Mar 2013
    Brierley Hill
    P.s thanks for the doc though theres always learning to be had....... Shall give it the once over tonight.
  1. MPG on A6 2.0 TDI DPF - on a good run is 32mpg!
    By Jaggy74 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-01-2013, 03:17 PM
  2. In Car Owners Manual (and MMI manual) on your PC
    By ScottyUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-09-2011, 08:08 PM
  3. car manual service manual
    By tazmania_1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-11-2010, 11:12 PM
  4. Question Will workshop manual tell me the same as the owners manual
    By reprobate in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-07-2010, 11:20 PM
  5. Please Help Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    By flying fish in forum Touran - Sharan - Caravelle
    Last Post: 08-11-2008, 11:56 PM
