Thread: Reducing chances of D3 Audi A8 Air Suspension Failure?
  1. Reducing chances of D3 Audi A8 Air Suspension Failure?
    Nov 2012
    Cardiff, UK
    Hey Guys,
    What steps can I take to reduce the chance of my air suspension failing? I heard someone mention changing the compressor relay fuse?
  2. Re: Reducing chances of D3 Audi A8 Air Suspension Failure?
    Jan 2010
    United Kingdom
    Yep - cheap fix, the relay is under the front passenger carpet and there are posts on here about how to do it. From recollection it's about £10 for the part and is a fairly straightforward DIY. Definitely worth doing as they can wear to the point where they bridge and then the compressor keeps running until it burns out which is the wrong side of £1k to sort out.
    Apart from that, be very wary of wading through deep puddles - the compressor is on the left hand side of the engine bay at the front bottom (down by the intercooler). In other words ideally positioned to hoover up puddles thereby killing it.
    Not aware of anything else - I did see something on a forum somewhere about not leaving it in dynamic mode all the time but never found anything to substantiate that (and I think the 'sport' models are in what amounts to dynamic all the time anyway) and mine lives in dynamic all the time because the ride is better.
  3. Re: Reducing chances of D3 Audi A8 Air Suspension Failure?
    Jan 2010
    Northants
    Definitely change the relay. It is a well known issue and it’s only a 10 minute job to change, it cost me a small fortune. Make sure you get the replacement relay from Audi (about £15) and tell them what it’s for, they upgraded the relay a few years ago and I think it has a different part number from the original. It’s in the passenger foootwell near the orange fuse. See this post for more info> Please Help A8 Air suspension light is on
  1. Question Reducing Noise
    By JettaMkV in forum Jetta MK3 - 2005 - 2013
    Last Post: 08-02-2011, 09:55 PM
  2. Question Smelly air con and hissing when reducing acceleration.
    By John-Currie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-06-2010, 12:16 AM
  3. Mot failure on suspension
    By danielintheuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-01-2010, 06:04 PM
  4. Replacing leaking rear suspension air bag - Audi Allroad
    By paul b in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2009, 10:00 PM
  5. How many chances do they get?
    By andy8442 in forum Chat - Anything with wheels
    Last Post: 12-12-2008, 04:53 PM
