Thread: USB Interface
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. USB Interface
    Picked up my Golf GT this morning. Asked to swap the Iphone lead for a USB one and was told that wasn't possible.
    The salesman was a bit useless to be honest. I've tried the USB MDI cable from my old MK6 and it doesn't work.
    Can anyone give me the part nr for the new USB lead for the mk7 please?
    DaveB
  2. Re: USB Interface
    Mar 2008
    According to ETKA there is an "adapter wiring set for MDI interface" and the part number is 000 051 446 B and the cost is listed as £31.97.
    There also seem to be some units which are called "connection for usb and aux-in" which have 3 differenr part numbers - 5G0 035 222, 5G0 035 222 C and 5G0 035 222 D which seem to be for different models and they are priced at £21.48.
    I suggest a visit to the dealer and a word with the parts department and they can then show them to you on their copy of ETKA and work out which item is most suitable for your particular car. Perhaps you could then inform the salesman and suggest he pays for which one you need.
    Any problems come back to me and I will send you a print out from my copy of ETKA.
  3. Re: USB Interface
    Quote Originally Posted by h5djr View Post
    Thanks for the info. Can you confirm those leads are different from the mk6 USB lead? - Just to make sure that the issue is with the lead and not the USB flash-drive I have.
    DaveB
  4. Re: USB Interface
    Mar 2008
    Quote Originally Posted by DaveB666 View Post
    The illustration and part number for the lead IS the same as for a 2012 Golf - 000 051 446 B. So perhaps it's the lead that is the problem.
  5. Re: USB Interface
    Feb 2009
    Dave B,
    I have tried the USB lead from my Mk6 in My 7 and one that my dealer sent me foc but find that my Samsung mp3 player isn't recognised. Interestingly a USB stick loaded with music works with the same lead and I'm wondering if it has something to do with the USB2 standard. I'll be interested to hear how you get on (and the part number for the lead if you find one that works).
    VW Golf VII SE 2.0 TDI, Deep Black Pearl
  6. Re: USB Interface
    Quote Originally Posted by Hotspur View Post
    Dave B,
    Are the 2 leads you have the same?
    DaveB
  7. Re: USB Interface
    Feb 2009
    I'll have to check the part numbers to confirm but I believe they are likely to be the same number altough one was manufactured in China and the other Slovenia I believe.
  8. Re: USB Interface
    I've had abit of a play this weekend with mine. Using the MK6 lead a 2GB USB stick works, as does a 4GB stick.
    An external 500GB HD and 32GB USB stick does not.
    All were formatted to FAT32.
    I think I might just buy a large SD Card, but need confirmation of the largest compatible one that will work first before I do. I want a 64GB one ideally.
    DaveB
  9. Re: USB Interface
    South London. UK
    Before I bought my MK6, I purchased a Zen mp3 player/radio and then realised, from those who know better, that all I needed was a USB memory stick. I think the one I bought was 8GB and so put all my classical albums on that and that was plugged into my car, using the lead already there under the armrest. It works fine and means I don't have to leave an expensive (or cheap) mp3 player baking in the summer heat or freezing in winter, in the car.
    I hope that, if I buy the MK7, this USB stick can be snucked away in the appropriate place and used again with the correct lead. I believe this is behind the spring loaded flap by the gear lever.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  10. Re: USB Interface
    Quote Originally Posted by HHGTTG View Post
    I hoped the same, but using a 32GB USB stick; doesn't work.
    DaveB
  1. VCDS HEX-USB+CAN Interface
    By stuart in forum Site Sponsors - Current Group Buys
    Last Post: 25-11-2014, 06:31 AM
  2. Just installed Anycarlink USB interface to my RNS MFD Radio
    By andrewguen in forum In Car Entertainment
    Last Post: 19-07-2010, 08:29 AM
  3. Question Usb to oem interface
    By lemurz in forum In Car Entertainment
    Last Post: 11-07-2010, 11:19 PM
  4. Want to buy HEX-USB+CAN Interface
    By a4audio in forum VCDS - General Questions
    Last Post: 08-04-2010, 12:53 PM
  5. USB Interface
    By MFGF in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 17-09-2009, 05:47 PM
