Thread: Stutter at start up??
  1. Stutter at start up??
    Oct 2010
    Crewe
    Hi Guys,
    Over the past 8 months or so, I've noticed a stutter / miss at start up. (2.0 tdi BKP - 2006 - injectors and loom change 16 months ago).
    What happens is - push keystart, engine fires up quickly but sounds like it runs on 3 cylinders for a couple of seconds - then catches on all 4 cylinders fine, without me touching the throttle.
    Only happens when the car is stone cold. If I start it, immediately stop it and start again it runs fine.
    Outside temperature doesn't seem to affect it either - today at -2.5c fired on all 4 cyl first time after glowplug light extinguished. Other days at warmer (or colder temps) it will miss.
    Any ideas guys??
    ...BTW - runs ok otherwise (although does use a bit of oil)
    Ta
    Rich
  2. Re: Stutter at start up??
    Apr 2010
    Ashford, Middlesex
    One of the traits that I don't miss - I never did get to the bottom of it with mine, so can't help I'm afraid.
    I did wonder about glowplugs with mine, but then dismissed the thought because it would generally start as sweet as a nut when it was baltic cold, and only muck around when it was chilly or a bit warmer. Oddly, staring it on a really warm morning it would never do it either.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  3. Re: Stutter at start up??
    Dec 2009
    14 Post(s)
    I have the same car/engine. Mine has had its battery replaced. Not bad when you think it was original and car is 8yrs old November.
    Car starts 100 times better and seems better on start up. No lumpy running from the start.
  1. help stutter/misfire
    By jamedvickni in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2010, 02:50 PM
  2. Please Help Engine 'stutter'
    By Rockape301 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2010, 03:28 AM
  3. t5 engine stutter
    By ian.m in forum The Commercial Range
    Last Post: 14-10-2009, 09:28 PM
  4. stutter while driving
    By dirtyderv in forum Bora - 1998 - 2005
    Last Post: 12-06-2008, 08:48 AM
  5. GT TDI Stutter
    By phil_w in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 10:19 AM
