Thread: Engine Fan Constantly Running
Results 1 to 8 of 8
  1. Engine Fan Constantly Running
    Jan 2013
    Limerick, Ireland
    The fan seems to be constantly running as soon as my engine warms up. I would of thought the car was overheating but the thermostat always is reading spot on. The coolant level also seems fine.
    If my car is stationary or I park it and leave the engine running the fan will kick in almost immediately, running at full speed for about 20seconds, stopping for around 5seconds then kicking in again for 20seconds and so on. The fan also stays on for about 10seconds after I have turned the engine off. This happens almost everytime I drive the car.
    Is there a reason for this or is it maybe a faulty sensor or something?
    2004 AUDI A3 2.0 140TDI, RED, 17'' ALLOYS, FACTORY XENONS, AUDI SYMPHONY STEREO
  2. Re: Engine Fan Constantly Running
    Aug 2011
    Meath
    Check the fan switch it might be faulty
  3. Angry Re: Engine Fan Constantly Running
    Jan 2013
    Limerick, Ireland
    During my investigation of why the fan keeps running I came across a plug at the front of the engine bay which I unplugged thinking it might be the fan just to see if it stopped...it didnt stop so I plugged it back in but since then "Airbag fault" is coming up on my display and the airbag light stays on...doubt its a coincidence
    Here are pics of the plug I unplugged, a yellow plug going into a brown connector.
    I think its just one of those days!!!
  4. Re: Engine Fan Constantly Running
    Bradford
    When i got my b6, it was my first turbo diesel, and if i ragged it the fan would carry on running even if engine was turned of. Turns out its to cool the turbo down and its normal. First time i panicked thought ***!! Ive knackered the car! Lol
  5. Re: Engine Fan Constantly Running
    Sep 2011
    Orpington Kent
    Quote Originally Posted by Imran View Post
    At a guess you may have dissed an inertia sensor related to air bags. Save you paying a dealer to clear the light, get yourself a cheap reset tool and reset it yourself. Else someone with knowledge can offer you other suggestions but your ecu needs to be reset in any case.
    Not sure about the fan running though, would be interested to know the solution, where is the fan/sensor switch anyway.
  6. Re: Engine Fan Constantly Running
    Jan 2010
    Ipswich, UK
    Quote Originally Posted by Dave_Bounce View Post
    That is the the front crash sensor that you have disconnected. The airbag light will only clear with the use of a diagnostic tool or VCDS. The fan control module is integrated into the bigger of the two fans, so if it is faulty you will have to replace the whole fan which costs about £250 from VW. I assume you don't have the air con on as both fans will always turn at a low speed when it is on.
    2011 A6 Avant S-Line Special Edition 2.0 TDI 170 Multitronic
    - Phantom Black, Technology Package - High (HDD Nav with 3G MMI), 19" 5 Segment Spoke Alloys, Factory Privacy Glass, OEM LED Number Plate Lights, All the Usual S-Line Refinements.
    Previously...
    2005 VW Passat B6 2.0TDI 140 Sport - (BKP Engine)
  7. Re: Engine Fan Constantly Running
    Aug 2011
    Meath
    If the fan is on all the time the engine will be running cool and over fuelling
  8. Re: Engine Fan Constantly Running
    Jan 2013
    Limerick, Ireland
    Quote Originally Posted by nigos View Post
    Quote Originally Posted by Doctle Odd View Post
    Thanks for the replies...at least I know how to sort the problem now...Being the idiot I am I shouldnt of disconnected the plug (don't fix something if it isnt broken and all that).
    I have aircon in my Passat but I havent turned it on to see if the smaller fan is running...it is the larger one that continues to run.
    And doctle odd I have noticed my fuel consume is quite poor from what I had expected from the Passat so that would make sense
    Appreciate the help
  1. Main cooling fan running constantly
    By CharlesElliott in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2013, 08:48 PM
  2. Question Fan running Constantly
    By rwavant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-06-2012, 05:23 PM
  3. Please Help Engine fan constantly on
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2012, 08:42 PM
  4. Replies: 6
    Last Post: 05-09-2011, 02:14 AM
  5. Please Help Any ideas for Engine fan constantly running?
    By warriorsage in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-12-2010, 11:09 AM
