Thread: ESP, Crash sensor and other error lights.
  1. ESP, Crash sensor and other error lights.
    Oct 2009
    Leamington Spa
    Need your help again please.
    It maybe a coincidence but my 2005 A6 had an MOT, windscreen replaced and new rear tyres fitted. A day later error lights start lighting up the dash. The ESP light came on, the passenger side Air bag light, and the engine check light. I took it to my local garage who checked the scan which also highlighted glow plug problems. He replaced all the glow plugs cleared the codes and for a few days all was fine. In the rain the esp light came on again and the air bag light. The scan records a problem with the passenger side crash sensor but nothing for the ESP. If I press the brake pedal the ESP light start to flash. The garage cleaned the connections to the crash sensor and the light went out. Yesterday I was driving in the rain for the first time since my last garage visit and the ESP light was behaving as before, on solid and the flashing when I braked. To make matters worse, the power steering was really hard. I stopped the car for a few minutes and the steering was okay. Can you help with any of these issues please, mainly the rain and the ESP light.
    Thursday,07,March,2013,19:41:10:58237
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Chassis Type: 4F0
    Scan: 01 03 05 07 08 09 15 16 17 19 1E 37 42 46 47 4F 52 53 56 61
    62 67 72
    VIN: WAUZZZ4F56N112463 Mileage: 238470km/148178miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Part No SW: 03G 906 016 HS HW: 028 101 255 7
    Component: R4 2,0L EDC G000SG 9673
    Revision: --H01--- Serial number:
    Coding: 0000072
    Shop #: WSC 00212 210 90008
    VCID: 7BFF031A3A061DC074E
    1 Fault Found:
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 000 - Open Circuit
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 238191 km
    Time Indication: 0
    Date: 2013.03.06
    Time: 08:11:58
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.48 V
    Bin. Bits: 00101000
    Temperature: 4.5°C
    Bin. Bits: 00110000
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H04 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020855
    Shop #: WSC 02325 785 00200
    VCID: 2C5DF0468FE84A78AD4
    No fault code found.
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10604000294982
    Coding: 0000017
    VCID: E3CFDB7A22B64500DCE
    Part No: 4F0 910 131 D
    Component: FBSAUDIC6 EZS H45 0070
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H39 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350LU057626318
    Coding: 0001002
    Shop #: WSC 02335 785 00200
    VCID: 254B0562EC027B3072A
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 F
    Component: KLIMABETAETIGUNGH05 0160
    Revision: 00000028 Serial number: 00000000205147
    Coding: 0001044
    VCID: DBBFE39A1AC67DC094E
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
    Component: ILM Fahrer H15 0190
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0000101
    VCID: 2B5FF35A8AE64D40A4E
    Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH11 0050
    Coding: 00141886
    Shop #: WSC 02335
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0260
    Revision: 07H29000 Serial number: 0037LD0B26FZ
    Coding: 0013381
    VCID: 29530952801A5F50562
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026053160641
    Coding: 0102041
    Shop #: WSC 02323 785 00200
    VCID: E6C9C26ED18430283B0
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
    Component: KOMBIINSTR. M73 H11 0630
    Revision: 00100000 Serial number: 4RA12C8C5
    Coding: 2308443
    Shop #: WSC 00579 210 91872
    VCID: 1E392A8EC954A8E8330
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 1300805B150306
    Coding: 6CEE53C42B6104
    Shop #: WSC 02334 785 00200
    VCID: 27570F6A960E6920406
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBE8017114
    Shop #: WSC 00000 000 00000
    VCID: 1C3D2086DF48BAF8DD4
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H47 1060
    Revision: 00000000 Serial number: 364LU057515451
    VCID: 3B7FC31A7A86DDC034E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0080
    Revision: 00000000 Serial number: Q@
    Coding: 0002586
    Shop #: WSC 02327 785 00200
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01008657840000
    Coding: 0000251
    VCID: 2E59FA4EB9F43868830
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 C HW: 4F0 035 223
    Component: Amp.-ASK H10 0320
    Revision: 31S00001 Serial number: 01511050177211
    Coding: 0000001
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000158087
    Coding: 0001104
    VCID: DEB9EA8E09D468E8F30
    1 Fault Found:
    01797 - Power Steering Hydraulic Pressure Valve (N315)
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 199
    Mileage: 238428 km
    Time Indication: 0
    Date: 2013.03.07
    Time: 18:50:00
    Freeze Frame:
    Voltage: 13.600 V
    Temperature: 10.0°C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0080
    Revision: 00000000 Serial number: 2“
    Coding: 0002586
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Revision: C63C0030
    Coding: 0000111
    VCID: DDBBED8204D273F0EAA
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 352LV057606913
    Coding: 0000001
    VCID: 3163E132A8CA27909E2
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000155650
    Shop #: WSC 00236 210 08365
    VCID: 234F1B7AE23685001CE
    Subsystem 1 - Part No: 4F0 915 105 C
    Component: von VA0 1511080566
    Coding: 344630393135313035432056413031353131303830353636
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0002050
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000703080260
    Shop #: WSC 12336 024 394758
    VCID: 3669D22E41A400A8CB0
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0002050
  2. Re: ESP, Crash sensor and other error lights.
    Ambler, PA, USA
    So, we replaced the windshield and then on rainy days we have unknown electrical issues? Does this not suggest that perhaps there is a water leak? Water can cause all sorts of crazy issues... eventually it will cause permanent failures.. I'd start with a good inspection with hose on the windshield to see if water is getting in....!
  3. Re: ESP, Crash sensor and other error lights.
    Oct 2009
    Leamington Spa
    Thanks Bruce, sorry should have said, thats one of the first things i did, hose the windscreen down, and rear wheels but no error lights. I have been to the garage 3 times now, replaced the brake light switch, had the stering wheel angel thingy done, replaced the Glow plugs. The glow plugs were replaced as at the time that was the only error logged.
    I have also read that it could be a sensor on wheel or the MAF, help as this is costing a fortune.
  4. Re: ESP, Crash sensor and other error lights.
    Aug 2011
    Meath
    If the steering is heavy sometimes it could be a sticking pump or alternator pulley failing
  5. Re: ESP, Crash sensor and other error lights.
    Oct 2009
    Leamington Spa
    The power steering fault and issue only happened once and it went away after i trurned the ignition off for a few minutes. I have no error lights on now and it rained the other day and no ESP fault light. Why would the warning light come on but nothing logged.
  1. Please Help A4 Crash sensor location
    By scooby_d0o in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-11-2023, 08:58 PM
  2. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  3. Crash Sensor
    By MikiebV6 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-05-2011, 12:05 PM
  4. Please Help Audi A4 Crash sensor?
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-03-2010, 03:59 PM
  5. Crash Sensor Location
    By gary.kite in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-11-2008, 07:51 AM
