Thread: Steering Angle Sensor needs calibrating?
  1. Steering Angle Sensor needs calibrating?
    Aug 2011
    Newcastle upon Tyne, UK
    Having replaced a faulty Steering Angle Sensor or "Squib" I now find that my airbag warning light goes out when erasing the fault code but immediately comes back on. This is now joined by both ABS & ESP warning lights and red handbrake warning light flashing. After contacting local VW breakers was told that the newly installed sensor would need calibrating to the ECU and referred me to an Auto Electrics specialist. I know that the VW breaker has VAGCOM diagnostics and so assume that this is not something that can be done using VAGCOM as he referred me elsewhere. The mechanic who fitted the sensor said that he has fitted these sensors in other cars previously and they have never required calibration. Can anyone verify what I have been told and also if this is something that can only be carried out by a specialist?
  2. Re: Steering Angle Sensor needs calibrating?
    london/ UK
    Are you driving the car mate ? You need to drive in a straight line for 10-20 meters before the fuzzy logic resets itself !
  3. Re: Steering Angle Sensor needs calibrating?
    Bradford
    I had to do mine a while back, you (obviously) need vcds, then perform the following:
    Basic Setting
    Sensor for Steering Angle (G85)
    Important Note: This applies only for Models with Conti/Teves MK70 ABS/ASR. For Conti/Teves MK60 ABS/ASR/ESP look at Vehicle specific specific Procedures in ABS System documentation.
    Prerequisites:
    Start the vehicle.
    Turn the steering wheel one turn to the right and one turn to the left.
    Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    Ensure that the steering wheel is not moved again.
    Keep the engine running and do not switch off the ignition.
    System voltage at least 12.0 V.
    [Select]
    [44 - Steering Assist]
    [Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 1 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    [Measuring Blocks - 08]
    Group 007
    [Go!]
    Check field 1, the value has to be between -1.5 and +1.5 °.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
    Original link:
    VW Golf (1K) Steering Assist - Ross-Tech Wiki
    EDIT
    oops! Just realised, the above may only be for a b6...
  1. Steering angle sensor
    By Caddy2k in forum VCDS - Help Requests
    Last Post: 19-09-2012, 04:45 PM
  2. steering angle sensor? which one?
    By baz_baz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-02-2012, 02:38 AM
  3. steering angle sensor
    By dubber dude in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-01-2011, 08:45 PM
  4. steering angle sensor
    By cass62 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-04-2010, 11:05 PM
  5. Steering angle sensor
    By shugielog in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-11-2008, 08:43 PM
