Thread: split relay charging line
  1. split relay charging line
    Kinross Scotland
    Does anybody know of a good way to run a feed direct from the battery to the boot or can a constant live feed be found on the fuse panel on the side of the dash. (golf hatch 2008). reason is to install a spit relay in the boot to charge battery in caravan on the move. finding a path through the bulk head is a bit difficult and i do not want to go under the car.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  2. Re: split relay charging line
    Aug 2011
    Meath
    You should be able to sun a cable under the plastic trims between the carpet and the door openings, they're easy to get off
  3. Re: split relay charging line
    Kinross Scotland
    Quote Originally Posted by Doctle Odd View Post
    Thanks, but do you know how to get through the bulkhead to the engine compartment without drilling.
  4. Re: split relay charging line
    Aug 2011
    Meath
    TBH there's no easy way that I know of. I tend to drill a hole put in a grommet and go that way
  5. Re: split relay charging line
    Sep 2008
    chester
    17 Post(s)
    Have a look at the bonnet release cable on the o/side under the wiper motor,you may be able to move the grommet over a little.Or on the other side pollen filter.
  6. Re: split relay charging line
    Kinross Scotland
    Thanks to all who replied, just found a bit of good info which is the wiring diag for the TEC3 split charging relay which states that the connection for the permanent 12v supply can be at a suitable terminal on the fuse box instead of/or a direct connection to the to the battery. This will solve the problem of trying to get through the bulk head. I am thinking of unused position 44 on the "c" fuse box on the side of the dash
    http://www.psb-towing.com/shop/pdf/T...structions.pdf
    Any tech reason for not doing this please comment.
    Just found an excellent "howto" for adding extra cicuits to the fuse box on the side of the dash
    http://www.myturbodiesel.com/1000q/m...dd-circuit.htm.
  1. Question Split charge relay on vw t5 ???
    By chicargo in forum The Commercial Range
    Last Post: 30-09-2011, 09:20 PM
  2. split fuel line
    By wilks in forum 80 - 90
    Last Post: 19-04-2011, 08:34 PM
  3. Replies: 7
    Last Post: 06-12-2010, 12:43 AM
  4. Battery charging
    By FIBAMAN in forum Jetta MK3 - 2005 - 2013
    Last Post: 03-12-2010, 09:15 PM
  5. Attention Split metal fuel line, 1.8T
    By Redbrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2009, 03:53 PM
