Thread: Crunch in second gear, 1.9tdi 130 awx
Results 1 to 10 of 11
  1. Crunch in second gear, 1.9tdi 130 awx
    Feb 2013
    blackburn lancashire
    my car often crunches when pushed in to second gear, drives well when in it however in order to avoid the crunch i change in to second gear slowly,
    is my gearbox on its way out?
    it seems fine besides this.
  2. Re: Crunch in second gear, 1.9tdi 130 awx
    Do you normally double-de-clutch. You may have a worn syncro ring. Is the clutch bite point normal. Regards Peter
  3. Re: Crunch in second gear, 1.9tdi 130 awx
    Feb 2013
    to be entirely honest i purchased the car this way many months ago,
    i do give the car a good blast but i do not double de clutch, i simply drive to high revs,
    i always change gears smoothly and especially with this fault.
    There is a slight judder on the clutch however bite is perfect, i believe that is not related
    what is the solution?
    will gear oil change not help?
  4. Re: Crunch in second gear, 1.9tdi 130 awx
    Aug 2006
    it might be worth trying a thinner oil in the gearbox,i spoke to a gearbox specialist about mine as that sometimes has slight resistance going from 1st to 2nd,mainly when the outside temp is very cold,on a warmer day its not really noticeable and he said try a thinner oil to start with,if not then if it got worse it could be 2nd gear synchro starting to play up,mines a 52 plate and done 51000 from new.
  5. Re: Crunch in second gear, 1.9tdi 130 awx
    Feb 2013
    how do i change the oil? is it a mechanics job or DIY.
    And also if the second gear synchro is the problem then what is the solution?
  6. Re: Crunch in second gear, 1.9tdi 130 awx
    Apr 2009
    Epsom Downs
    If the synchro is the problem, and an oil change doesn't fix it, it's gearbox out time, I'm afraid..
    Can you get around the crunch with a bit of double de-clutching?
    If you can, your wallet will thank you if you keep on doing it.
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  7. Re: Crunch in second gear, 1.9tdi 130 awx
    Feb 2013
    ok i will attempt a gear change, any one know how to tackle this.
    and yes i can aovid crunch by simply changing it slowly, so i think i will keep it as it is
  8. Re: Crunch in second gear, 1.9tdi 130 awx
    Apr 2009
    Epsom Downs
    I'm assuming the crunch is when going down the gears?
    If so, do the following when going from 3rd to 2nd:-
    Clutch out-change out of third
    clutch in-rev-up
    Clutch out-into second (should be without a crunch)
    Doing this becomes second nature after a while, and results in smoother changes even if the synchros are ok.
    Still worth changing the gearbox oil though, there's loads of little, hard bits of metal sloshing around the gears and bearings....
    Allroad 2.7 TT 2004
  9. Re: Crunch in second gear, 1.9tdi 130 awx
    Feb 2013
    how do i go about changing the gear oil? the weather seems to be getting slightly better now so want to give it a go!
  10. Re: Crunch in second gear, 1.9tdi 130 awx
    Apr 2009
    Epsom Downs
    As a confirmed "automatic-man", I've not got oily on a manual boix for more years than I care to remember, but there should be a drain plug and a filler/level plug (which are.....errr.....self-explanatory!).
    Audi being Audi, there may not be. Time to look on the ELSAWIN, I guess.
    remember to get the box good and hot before draining, it's very viscose and will take an age to drain otherwise.
    Allroad 2.7 TT 2004
  1. gear box crunch
    By crashcarter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-01-2012, 12:22 PM
  2. Question egr valve for 2003 1.9tdi 130 awx engine
    By spartan80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2010, 04:03 PM
  3. Please Help a3 2nd gear crunch
    By simin in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-08-2010, 12:51 PM
  4. 2nd Gear crunch
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-09-2009, 09:01 PM
  5. Second gear crunch 1.9 TDi S
    By superstevie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2009, 09:50 PM
