Thread: Passat 2008 turbo actuator fault
  1. Passat 2008 turbo actuator fault
    Mar 2012
    essex
    I Have read that if you have a turbo actuator problem that you can free it up by pumping it manually, just wondered if this was the case and if so the locattion of it in the engine bay
    Jason
  2. Re: Passat 2008 turbo actuator fault
    Aug 2011
    Meath
    You'd need to lubricate it as well
  3. Re: Passat 2008 turbo actuator fault
    Up North
    Turbo ACTUATOR is a vacuum unit. If it don't work you need a new 'un.
    TURBO ACTUATION can't be freed by pumping it manually, at least not for long. Maybe long enough to sell it to some mug, if you are lucky. That would be very ungentlemanly conduct that shouldn't be encouraged.
    All that pumping it does it to help you diagnose a problem inside. It then needs removal and either replace/refurb/clean out.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  4. Re: Passat 2008 turbo actuator fault
    Norfolk
    It has never been possible to free an actuator by pumping or lubricating it. On a pd you can vacuum test to see if it works. Common rail actuator are electric so nothing to pump..
  5. Re: Passat 2008 turbo actuator fault
    Mar 2013
    Lancaster England
    ive had the same problem! If it is comeing up with a fault code its more than likely that the diaphragm inside actuator is goosed!! if this is the case then you will need a wastegate repair kit from vw witch costs £98 but you will also need a vw specialist to fit it as the adjustment needs to be bang on otherwise it wont put the light out and you will run the risk of further damage! at a main dealer you will be looking at 1.5 hours labour!
  6. Re: Passat 2008 turbo actuator fault
    May 2010
    Colchester England
    Quote Originally Posted by Fennerlad View Post
    ive had the same problem! If it is coming up with a fault code its more than likely that the diaphragm inside actuator is goosed!! ...
    Actually, it seems to be the lower seal rather than the diaphragm that fails. When they install it, the actuator rod is not held and the seal gets twisted. Over time it develops a split. I have heard of people squirting some silicone sealant at the split to get it going again. How long it works for - I cannot say. You may benefit from heating up the shank of a 10mm ring spanner and bending it to about 100 degrees. It really helps when you are trying to get the bottom nut off the actuator rod.
  1. turbo actuator
    By meganall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2012, 01:28 PM
  2. 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    By BoyceyS4 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-06-2012, 03:20 PM
  3. Question Turbo actuator connector
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-06-2012, 03:02 PM
  4. I triggered the alarm fault on 2008 VW Passat
    By saldous in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-04-2009, 04:51 PM
  5. turbo actuator
    By mygolfygti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2009, 11:43 PM
