Thread: 2.5 tdi Whine at low revs
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. 2.5 tdi Whine at low revs
    Feb 2010
    Cambridge
    My a6 has an annoying whine from almost tick over up to 1500rpm. I suspected the turbo since it makes a siron sound if you up and down the revs however over 1500 rpm it doesn't make it any more.
    any ideas what could cause this?
    A6 3.0 TDI Le Mans
  2. Re: 2.5 tdi Whine at low revs
    london/ UK
    Could be a dry bearing, the v6 has a few of them rollers...
  3. Re: 2.5 tdi Whine at low revs
    Feb 2010
    Cambridge
    Ive take a video to see if it helps, what do you mean by roller?
    A6 3.0 TDI Le Mans
  4. Re: 2.5 tdi Whine at low revs
    I would say it is one of the belt tensioners Either A/C Power steering of the Aux belt itself, possibly the alternator, you will need to listen around with a stethoscope. It could be the Toothed belt tensioner. Regards Peter
  5. Re: 2.5 tdi Whine at low revs
    Feb 2010
    Cambridge
    Thanks, it did have a new power steering belt and tensioner last year because a tensioner bolt snapped. I'll get someone to gently rev it and have a listen to the belts.
    A6 3.0 TDI Le Mans
  6. Re: 2.5 tdi Whine at low revs
    Jul 2011
    Norway
    For my old eares it sounds like this whine keep up its rpm long after the engine is back to idle. The only two things that does that is the alternator ( (freewheeling) and ofcourse the turbo.....
  7. Re: 2.5 tdi Whine at low revs
    Ayrshire, Scotland
    18 Post(s)
    I had a whine similar which changed with engine revs, ended up it was an idler roller for the serpentine belt, when ever I removed the belt cover the noise was trebled, In my case i think it wasnt helped due the the tensioner pivot bearing being worn which causes it to not pull the belt square on the roller. your going to have to try and trace the noise location somehow, takes peter D's advice on thestethescope, or a hose on the end of your ear to help stick it where you cannot reach.
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  8. Re: 2.5 tdi Whine at low revs
    london/ UK
    No freewheel/clutch pulley on the aternator on v6 tdi...
  9. Re: 2.5 tdi Whine at low revs
    Jul 2011
    Norway
    Wasn't paying attention to the engine type, just listening to the lovely sound of a alternator/ freewheel bearing or a turbo with a leak or a short time to live....
  10. Re: 2.5 tdi Whine at low revs
    Feb 2010
    Cambridge
    Well I tried to get my wife to sit in the car and rev it a little, but she wasn't much help. I'm fairly sure it wasn't coming from the turbo, but will get my dad to give me in hand when I next see him. It does need a new cambelt soonish (would these bearings be replaced at the same time?) and I have seen I can get a refurbished turbo for just under £300 or I could cut my loses and buy a different car with different problems.
    A6 3.0 TDI Le Mans
  1. 2.0 TDI hesitating at low revs
    By limawhiskey in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2012, 01:56 PM
  2. Please Help Smokey 2.0 TDI , less power at low revs
    By iany in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-09-2010, 04:21 PM
  3. Golf 1.4 TSI Turbo Howling/Whine Noise at Low Speed/Revs
    By nnchokshi in forum Golf MK5 - 2004 - 2009
    Last Post: 15-10-2009, 09:38 AM
  4. Please Help Passat TDI PD130 kangarooing at low revs low load
    By phil2401 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-09-2009, 06:14 PM
  5. 1.9 TDi 150, 'lump' at low revs.
    By Breesey in forum Golf MK4 - 1999 - 2004
    Last Post: 30-10-2007, 12:30 PM
