Thread: car cut out, oil pressure warning!! What's the drill?
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
  1. car cut out, oil pressure warning!! What's the drill?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Hi all. The day I've been dreading has arrived. The oil pressure warning light came on the DIS just now as the car cut out. At first, I thought it had just stalled, but when I tried to restart, it just kept turning over without firing up.
    So what do I do? The car's parked in an awkward position, so I think I need to try to restart it to get it back on the driveway unfortunately.
    The Only Way Is A6!
  2. Re: car cut out, oil pressure warning!! What's the drill?
    london/ UK
    Injectors ? How's your oil pump drive ?
  3. Re: car cut out, oil pressure warning!! What's the drill?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Brycie View Post
    Don't restart mate... I'd really think about getting a neighbour/friend or breakdown to help you out moving car...
    As you are already aware if it is the oil pump drive then you really don't wanna be starting her up...
    Sorry to hear of this Brycie... lets hope it is something not major more like a fuelling issue or something...
  4. Re: car cut out, oil pressure warning!! What's the drill?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    There has been some white smoke on startup the last few months, wpuld that indicate injectors rather than oil pump?
    The Only Way Is A6!
  5. Re: car cut out, oil pressure warning!! What's the drill?
    Aug 2011
    Meath
    White smoke can just be condensation on a cold start. Can you get her towed/pushed back on to the drive? Don't turn it over until you check it out mate
    2 1 0
  6. Re: car cut out, oil pressure warning!! What's the drill?
    Sep 2011
    When I changed my injectors and fuel rail was low on fuel,etc... I got the low oil pressure warning on DIS... as car turned over to build up pressure,etc but failed on first cranking...
    Really can't say much from info you have currently besides I only have experience of the engine in my car...
    But will root around for data... have you scanned with your VCDS?
    1 1 0
  7. Re: car cut out, oil pressure warning!! What's the drill?
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Gah, not good And mine is the same age as yours (57 reg?) Hope it's nothing too expensive!
  8. Re: car cut out, oil pressure warning!! What's the drill?
    Too much of a coincidence it cutting out the oil light coming on. You may have had a cam belt failure. Do not try and start the car. Regards Peter
    3 0 0
  9. Re: car cut out, oil pressure warning!! What's the drill?
    Jul 2011
    Near Uxbridge
    Sorry to hear Paul.....fingers crossed that its nothing major and she's back on the road very soon!
  10. Re: car cut out, oil pressure warning!! What's the drill?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Thanks fellas. I've just left her in the road (we're second from end in a cul de sac anyway). Green Flag are on their way. I was going to check the white smoke out when weather was warmer, as like you say Doc, condensation can look like white smoke. Guess I ran out of waiting time. I'm fairly sure it is smoke though, not heavy, just a few whisps really.
    One weird thing, when it cut out & I instinctively tried restarting, the key stuck in the crank position & it kept turning over without me touching the key. Then I saw the oil pressure sign & removed the key & coasted back down the hill to our house.
    I'd need to reinstall vcds Gup, as I had it installed on my old laptop which I gave back to work. Didn't have time to load it onto our laptop this morning unfortunately.
    Cambelt was changed 40, 000 miles ago, so I'd hope it isn't that.
    Andrew, Mine's September 06 build, so is on the cusp of when they fixed the oil pump issue, so yours being 57 plate, you should be ok I'd have thought.
    Car's gone to the garage now, so I just have to wait for news. Will keep you all posted.
    The Only Way Is A6!
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  3. Oil Pressure Warning
    By paulpingu in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-06-2010, 07:51 AM
  4. Oil pressure car cut out Golf MK iV tdi
    By fovey14 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2010, 04:54 PM
  5. VW Golf Mk4 1.6 6v - Oil pressure problems/Random battery cut
    By paresh0407 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 10:53 PM
