Thread: Touran 2006 Cruise Control Fault
  1. Touran 2006 Cruise Control Fault
    Feb 2013
    France
    Just bought this 1.9 PD SE version even though the CC wasn't working. A few minutes into the test drive a warning light for a break light failure came on. We stopped, replaced the faulty bulb and carried on. I activated the cruise control swithch and pressed SET at about 60mph and the CC dash light came on, but there was no CC activity. Tried it several times but no luck. I have heard that a faulty brake light can prevent CC from working, but now it's replaced shouldn't it work ok - particulary as the CC dash board light does come on with the switch. Any advice would be great.
  2. Re: Touran 2006 Cruise Control Fault
    46 Post(s)
    It may need a brake or clutch switch. A scan with vcds would confirm this though.
    Sent from my iPhone using Tapatalk 2
  3. Re: Touran 2006 Cruise Control Fault
    May 2012
    doncaster england
    Try lifting the clutch and brake pedal with your feet as you press set! If its not set correctly could affect it,
    Dan
  1. Question Touran cruise control intermittent problem
    By mrobert in forum Touran - Sharan - Caravelle
    Last Post: 08-09-2012, 09:39 AM
  2. 2006 Touran 1,9tdi, fault code 01025
    By rally1 in forum Touran - Sharan - Caravelle
    Last Post: 10-04-2012, 08:56 AM
  3. 2006 Caddy Cruise Control
    By andreweaves in forum The Commercial Range
    Last Post: 30-12-2009, 09:02 PM
  4. Please Help Polo Gti 2006 ESP & Cruise control HELP
    By faz_gee in forum Polo - Derby - Lupo - Fox
    Last Post: 25-03-2009, 10:37 PM
  5. Touran Cruise control not working
    By andemann in forum Touran - Sharan - Caravelle
    Last Post: 15-04-2008, 08:49 AM
