Thread: Mk3 GTI Loosing revs!
Results 1 to 10 of 18
  1. Question Mk3 GTI Loosing revs!
    Aug 2007
    Hi all,
    I have a problem with my R reg GTI. I have looked through alot of the other posts and I don't think it has been covered so far (opps if it has)
    Anyway, before any of this started, I could take the engine right up to just above 6000 RPM, then just as it would red line it would loose power. Fair enough, its been limited I thought, saves me blowing the engine!
    The GTI needed a clutch change, so I dropped it into a local garrage to get that done, when I got the car back, the clutch was excellent etc, Cool.
    Next day as I was driving it, I excellerated and at 5000 revs the engine started to splutter!!! When I change up gears, no probs untill I hit 5000 revs again and the same prob????
    The car starts to jerk violently as soon as 5000 is reached. Its as if the engine is being starved of air or fuel or sth!
    I cant see what the connection (if any) is with a clutch change, but it happened just after it.
    Any Ideas?
    Any helps appreciated.
    Cheers Pernic
  2. Lambda what??
    Aug 2007
    OK so I got my hands on a laptop from a friend of mine, with Vag-com software installed. I checked the car out with it and it came up with a few errors!
    3 Faults Found:
    00525 - Oxygen Sensor (G39)
    03-10 - No Signal - Intermittent
    00537 - Lambda (Oxygen Sensor) Regulation
    19-00 - Lower Limit
    When I clear these faults and go for a drive, the car is back to normal. The revs go right up to 6000+ again. If I turn off the engine and restart the engine again, the problems reaccur!
    Has anyone ever come accross these types of errors before? Or even know what "Lambda regulation" is?
    Are these sensors hard to replace?
    The final reading I did yesterday came out like this:
    Saturday, 25 August 2007, 09:50:52
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 037 906 ----
    Component and/or Version: SIMOS 4S 2104
    Software Coding: 00000
    Work Shop Code: WSC -----
    6 Faults Found:
    00625 - Vehicle Speed Signal
    16-00 - Signal Outside Specifications
    19-00 - Lower Limit
    27-10 - Implausible Signal - Intermittent
    00515 - Camshaft Position (Hall) Sensor (G40)
    03-00 - No Signal
    Oh God! Help
  3. Re: Mk3 GTI Loosing revs!
    7 Post(s)
    Try swapping the fuel injection system relay, the grey one.
    They are cause all manner of problems and as you are getting so many faults I'd think it'd be my Nr.1 suspect.
    About £20 from VW bless em.
  4. Re: Mk3 GTI Loosing revs!
    Aug 2007
    Cheers Col for the reply,
    The fuel relay, Hmmm I will have to have a look in the morning for that and order one from local VW Garage, could it really be causing all those problems tho.
    I suppose it might be the case when I think about it alright, When I clear the faults with the laptop and rescan the engine, it comes up clean, its only after a short drive or so that the apperent faults reappear!
    Hmmmm sounds promising!
    I'll try that out and keep you posted,
    Thanks again!
    Pernic
  5. Re: Mk3 GTI Loosing revs!
    Aug 2006
    Devon, UK
    Could it also be that the mechanic who changed the clutch has not connected the sensors up properly if he needed to unplug them?
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
  6. Re: Mk3 GTI Loosing revs!
    Aug 2007
    Ipswich
    Hi, I have had this problem before on a 1999 golf 1.8.
    If I remember correctly the mechanic had forgoten to connect a very important earth strap onto the gearbox after fitting a new clutch.
    The earth strap normaly runs down from the battery area & should be connected to the gearbox case.
    (With this lead left disconnected it may cause damage to other sensors as they will be used as substitute earthing pionts- thats why you get so many nutty trouble codes.)
    Best of luck & let us know what you find.
  7. Re: Mk3 GTI Loosing revs!
    Aug 2007
    Long day at work today, didn't get a chance to do much about the relay, I did have a look at the relay/fuse pannel, I have several grey relays in there. There are two dark grey ones and one light grey one in the bottom right of the pannel. Is the fuel injection system relay, this one?
    Earth strap? Hmmm very interesting! I will defo have a look at that tommorow, just have tofind the time somehow!
    Thanks guys for the info, I will have a look at those tommorow,
    Oh BigCol, Do you know which one that relay is?
    Cheers again
  8. Re: Mk3 GTI Loosing revs!
    Aug 2007
    Got the new relay yesterday, it was the light grey one in the bottom right of the box, no 167 on the outside and 191906383c written on the side. There was no fuel injector relay, but this one is labled as fuel pump relay.
    So I swapped it out and cleared the faults and went off for a drive, same problem occured grrrr, I checked the faults with the laptop and they were all back also!
    Then I checked the earth lead, It is connected to the gearbox alright, I wonder if it should be removed and the edges of it sanded for better contact? What do ye think?
    I will have to take another look at the relay box to see if there is another relay I could have missed?
    Any other ideas?
  9. Re: Mk3 GTI Loosing revs!
    Aug 2007
    i ahve the exact problem, im gonna change the 02 sensors on tuesday, got them ordered. ive already changed the distributer cap, rotor arm, spark plugs and leads, fuel filter, oil changed, if the 02 sensors dont seem to work, then id be heading for the coil pack and change the ground wire cos it looks bad to me, the one conected to the coil pack.. ok bye now.. on the mission to find that problem!!
  10. Re: Mk3 GTI Loosing revs!
    Aug 2007
    Interesting! You are having similar probs to me. Id be very interested to hear what happens after sensors are swapped.
    Drop us a line when you get the car back.
  1. Passat 1.9TDi Loosing coolant
    By boywithapassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-07-2009, 08:53 PM
  2. Judder in low revs
    By kalyman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-08-2007, 01:07 PM
  3. revving over 3000 revs
    By chris audi a4 in forum Audi A4 - Archive Topics
    Last Post: 21-03-2007, 04:55 PM
  4. New - Loosing Coolant water
    By pks68 in forum A8 - S8 - V8
    Last Post: 06-10-2006, 12:39 PM
  5. Juddering at low revs
    By juniper in forum Passat - Archive Topics
    Last Post: 26-08-2006, 08:31 PM
