Thread: Rumble coming through clutch pedal and back of engine when changing gears
Results 1 to 10 of 16
  1. Rumble coming through clutch pedal and back of engine when changing gears
    Aug 2012
    Southampton England
    Hi all,
    I have just chopped in my B7 A4 for a 54 plate A6 2.0ltr TDI SE.
    So far so good and it is lovely to drive (although a bit slower than my A4 )
    The only problem is when I pull away, depress the clutch to change gear and let the revs fall, there is a very noticeable knocking/rumble coming from the back of the engine/through the clutch pedal.
    It is incredibly annoying and concerning.. Anyone know what it could be?
    Worth mentioning, there is absolutely no slip
    Bump??
  2. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Mar 2008
    High Wycombe
    Simon. Are you sure yours is a C5 A6? I thought the 2.0 tdis were only introduced in the C6 models.
    I'd suspect the clutch release bearing is knocking, and I'd worry that it might be the DMF, and I'd hope that someone like crasher would be along soon to advise.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Aug 2012
    Southampton England
    No I am not convinced. It could be a C6 but cant seem to find the answer.
    I am worried its the DMF too. £900 all in including clutch!
    I am thinking of buying the parts from GSF and doing it myself.
    Any thoughts on that? Thanks for your input.
  4. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Mar 2008
    High Wycombe
    Quote Originally Posted by simonrk57 View Post
    Look at the rear numberplate. If it's in a black area with 2 red foglight spaces above it, it's a C5:
    If it's just paintwork around it, it's a C6
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Aug 2012
    Southampton England
    Its a C6 then.
  6. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Aug 2012
    Southampton England
  7. Re: Rumble coming through clutch pedal and back of engine when changing gears
    46 Post(s)
    C6 - ill move this to the c6 section
    Sent from my iPhone using Tapatalk 2
  8. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Hi all,
    So far so good and it is lovely to drive (although a bit slower than my A4)
    Bump??
    1) Was this fault/noise present during the test drive?
    2) How has the supplying dealer responded?
  9. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Aug 2012
    Southampton England
    No not that I could hear and it was a private sale..
    Does it sound like the DMF?
  10. Re: Rumble coming through clutch pedal and back of engine when changing gears
    Apr 2012
    Aylesbury, Bucks
    Rumbling on depressing the clutch, I'd guess release bearing, judder when engaging clutch DMF failing. FWIW you could fit a solid flywheel, but that may (by passing through theengine vibrations and not damping them as a DMF does) stress other parts of the transmission, allegedly. However as you can remap for 25-30% extra power without damaging the transmission, I'm not convinced.
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  1. Please Help golf gt 170 mk5 over reving when changing gears.
    By creasy in forum Golf MK5 - 2004 - 2009
    Last Post: 23-10-2014, 08:58 PM
  2. Please Help Audi a4 1.8se - low acceleration changing gears
    By murphyaii in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-06-2010, 10:15 AM
  3. clutch rumble noise ?
    By tdi alastair in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-05-2010, 11:07 PM
  4. Clutch pedal doesn't come back up !
    By pass&golf_tdi in forum Golf MK3 - 1993 - 1999
    Last Post: 16-09-2009, 08:58 PM
  5. changing gears when car starts from cold
    By eluminati in forum Audi A3 - Archive Topics
    Last Post: 06-02-2008, 12:19 AM
