Thread: allroad 2001 leaking fuel tank
  1. allroad 2001 leaking fuel tank
    Jan 2013
    barnsley
    decided to fill me motor up wi diesel after having a good weeks wage only to find diesel pisssing art from underneath sourced a new tank off ebay any one fitted one and is it a hard job cheers ted
  2. Re: allroad 2001 leaking fuel tank
    Ayrshire, Scotland
    18 Post(s)
    I would not fit a new tank just yet, check where the leak is, it is probably the rubber seal under the bench seat, a couple of £'s to change or if you filled it up to the neck dripping it may be drpping at the blocked overflow, confirm where the leak is coming from, pull up the rear bench seat and remove to access panels to check the 2 sender rubber seals under there
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: allroad 2001 leaking fuel tank
    Jan 2013
    barnsley
    Quote Originally Posted by bagpipingandy View Post
    regards
    Andy
    yeh will check thanks very much for ya time to reply
  4. Re: allroad 2001 leaking fuel tank
    I have the same problem. How do I check for a blocked overflow? On mine the diesel seems to be dripping down the offside of the tank after being filled (just drips).
  1. Cracked/leaking coolant expansion tank?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-07-2012, 08:56 PM
  2. a6 allroad 2001 fuel
    By chris.d in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-06-2012, 08:40 AM
  3. Allroad 2.5tdi - fuel tank unit
    By Budge1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-12-2011, 09:17 AM
  4. Question Leaking fuel tank
    By grahamgolftdi in forum Golf MK4 - 1999 - 2004
    Last Post: 18-07-2010, 09:39 PM
  5. Please Help Leaking petrol after full tank
    By cris_rover in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-09-2009, 08:07 PM
