hi everyone
having problems with a 05 touran which had battery charger connected to it with the positive lead off the battery
charger was connected to loose positive lead instead of positive terminal on battery (D'oh)
since happing there is a constant wirring noise from just behind battery (abs ?)
and the horn sounds when you put the key in but only until you press unlock button on key
i have scaned with vcds see below
thanks in advance for any light or which way to proceed ........
Derrol
Monday,25,February,2013,11:26:53:39698
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W100638 Mileage: 55620km/34560miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0D0851854
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67D7953D56F6C620806
1 Fault Found:
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 194.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021190
Shop #: WSC 00671 210 95608
VCID: 3A711C4975C48BC82F8
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EF
Component: Climatic PQ35 084 0404
Shop #: WSC 00000 000 00000
VCID: 6CDDEA114F10E578ED4
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001259791
Coding: 00890F020004100000120C000000000000087B075C
VCID: 3973034570C280D0262
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
006 - Short to Plus - Intermittent
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0ADZ3A
Coding: 0012338
VCID: 356B0F755CDA64B0C2A
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0000042
1 Fault Found:
00889 - Horn (H)
007 - Short to Ground
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 961 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003403
Shop #: WSC 00445 067 57207
VCID: 31633B65A8B248909E2
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 2A512C0985643B485F8
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B100C51
Coding: 3D3F1340078003
VCID: 2953D30580623050562
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0158
Coding: 0000116
VCID: F4ED72719720BDB8B54
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.6 1502
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 81E802087F2D8505485FC61011
VCID: 7BFFD94D3A7E72C074E
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
3 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB4F759C5AA4B082A
1 Fault Found:
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 010 0022
Coding: 0040400
VCID: 2F673D1DBE865E60886
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
1 Fault Found:
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 30653E61A3B8419891C
1 Fault Found:
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 18: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
