Thread: Clutch & DMF Advice Needed for an AVF 130
  1. Clutch & DMF Advice Needed for an AVF 130
    Aug 2008
    Somerset
    Just wanted the opinion of someone more in the know than I.
    My car has just crossed the 133K mile mark and the clutch has just started to slip.
    Not all the time only very occasionally and normally in third under heavy load.
    My question is do I change just the clutch or should I change the clutch and the DMF at the same time as the car is going to be in bits anyway.
    Your thoughts please gentlemen
  2. Re: Clutch & DMF Advice Needed for an AVF 130
    london/ UK
    Go for a Sachs clutch and flywheel, is your car remapped ? If it is then i would go for a Sachs SRE clutch with organic linings, better clamping pressure, higher torque rating and stock feel on the clutch pedal !
  3. Re: Clutch & DMF Advice Needed for an AVF 130
    Aug 2008
    Somerset
    Yeah its been remapped to 165bhp. So your advice is to change both ?
  4. Re: Clutch & DMF Advice Needed for an AVF 130
    london/ UK
    Yes, if the clutch slipped it would have overheated and damaged the pressure plate and the flywheel matting surfaces !
  1. DMF & Clutch replacement still faulty
    By r2sma in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2012, 02:24 AM
  2. Question Clutch & DMF DIY
    By APU in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-04-2011, 03:40 PM
  3. DMF & clutch replacement
    By KEY in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2011, 12:31 PM
  4. TDI Clutch & DMF Question
    By Audity in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2009, 07:43 PM
  5. DMF and Clutch for Golf 1.9 GT TDI 130(ASZ)
    By paradoxni in forum Golf MK4 - 1999 - 2004
    Last Post: 18-11-2008, 12:26 PM
