Thread: Volkswagen RNS-510 Sat Nav fitting
  1. Volkswagen RNS-510 Sat Nav fitting
    Sep 2012
    West Midlands
    Hi there, i have a VW Golf MK5 1.9S, and want to replace the standard stereo with a RNS-510. Is this easy? Anyone give me advice of how difficult it is to replace it?
    Where's the cheapest i can get one?
    Many thanks!
  2. Re: Volkswagen RNS-510 Sat Nav fitting
    46 Post(s)
    Easy to replace - you just need to remove the standard stereo and the rns slots in. It will have a quadlock connector but you will get a gps antenna with your new nav which can be set above the glovexbox when removed.
    you may need a new can gatway though to stop battery drain on early cars.
    all parts can be got from ebay/owners forums and you will need it coded with vcds
    VW AUDI Forum - VWAF
  3. Re: Volkswagen RNS-510 Sat Nav fitting
    Sep 2012
    West Midlands
    Mine's an 06. Would i need a new can gateway?
  4. Re: Volkswagen RNS-510 Sat Nav fitting
    Kinross Scotland
    Gateway replacement very likely, you need later than a "K" revision, 08-ish onwards. you will also need an antenna adapter (circa £8 on ebay), as although the RNS takes the two antenna leads that your rcd 300 uses it is a different socket arrangement. Removal is easy but get a set of trim tools 5 or 6 quid on ebay. see this example of removal on you tube.
    2008 Volkswagen GTI Radio Removal - YouTube
    You will also need someone to set it for you with VCDS.
    see this
    Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RNS 510, RCD 510) antenna adapter | my-gti.com
    Tiguan 2.0 4Motion 140PS 01/07/2013
  5. Re: Volkswagen RNS-510 Sat Nav fitting
    46 Post(s)
    One for sale on the forum ^^^^
    Sent from my iPhone using Tapatalk 2
  6. Re: Volkswagen RNS-510 Sat Nav fitting
    Sep 2012
    West Midlands
    Is the RCD510 cause the same battery drain problem? Is there any easier fixes!? Many thanks.
  7. Re: Volkswagen RNS-510 Sat Nav fitting
    Kinross Scotland
    Quote Originally Posted by ryang148 View Post
    The Battery Drain problem is model year Can Gateway related and is only a problem when you have a mismatch. see this article for more detail on this matter.
    The easy fix is to match up the can gateway with the RCD 510, but the Gateway can be a bugger depending on the model/grade of the car as this dictates where it is located.
  1. Please Help RNS 510 sat nav paking sensors park assist
    By Rob_Infiniti in forum Touran - Sharan - Caravelle
    Last Post: 11-05-2012, 02:24 PM
  2. Ebay alternative to VW RNS 510 Sat Nav
    By rjordan2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2008, 10:18 PM
  3. RNS-510 TouchScreen Sat Nav
    By eko in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2008, 10:20 PM
  4. Touchscreen RNS 510 Sat Nav
    By Trikster in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2008, 05:19 PM
