Thread: camshaft position sensor fault
  1. camshaft position sensor fault
    Winchcombe, Glos.
    Hello, i have been having a problem starting my 1.9 2006 tdi b6 passat when warm for a few days now, managed to get it scanned today and here is the result:
    Would this cause the problem? and can they be replaced easily? or even where is it? Any advice greatly appreciated
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 DP HW: 028 101 274 2
    Component: R4 1,9L EDC G000SG 7870
    Revision: --H02--- Serial number: VWZCZ000000000
    1 Fault Found:
    012295 - Camshaft Position Sensor (G40)
    P3007 - 000 - No Signal - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 254
    Mileage: 268833 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:43:06
    Freeze Frame:
    RPM: 1071 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.55 V
    Bin. Bits: 00101100
    Idle Stabilization: 0.0°KW
    (no units): 48.0
    Readiness: 0 0 0 0 0
  2. Re: camshaft position sensor fault
    Norfolk
    It's behind the top cam belt cover next to the cam wheel, Check the wiring in case any is damaged.
  3. Re: camshaft position sensor fault
    Aug 2010
    stoke-on-trent england
    May be some thing like happened to my 19tdi pd polo.Reluctant to start when hot, constant cranking of the engine drops the battery voltage and can throw up intermitent faults ie not real faults.after a full week of checking and diagnostics and a new cam sensor that failed to sove the problem,the starter motor was groaning under the extra work so i gave it a service and gave it a try,sounded good.whilst warming up the engine and doing scope checks on sensors i heard a pop,the egr valve had poped shut,had it been stuck open.I took it off gave it good de-gunking checked it worked ok (a good sucking on the pipe) all ok.put it all back together warmed up the engine,stopped it left it a minute tried the hot start condition"F I X E D".BEEN OK FOR 2 DAYS NOW,TOUCH WOOD.
  4. Re: camshaft position sensor fault
    Norfolk
    A live data scan would have told you the egr valve was stuck open.
  5. Re: camshaft position sensor fault
    Aug 2010
    Thanks martin,I must update my vcds to the full version and learn a bit more on how to use it,but would the egr stuck open have caused a no hot start condition.
  6. Re: camshaft position sensor fault
    Norfolk
    Quote Originally Posted by metalmicky10 View Post
    With the egr stuck open the engine doesn't get the correct air/fuel mix so it may well cause starting problems.
  1. Question Camshaft position sensor
    By paul.c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2012, 08:36 PM
  2. Fault code 19463 Camshaft position sensor
    By elliebumpkins in forum Golf MK5 - 2004 - 2009
    Last Post: 28-01-2012, 10:54 PM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. Please Help Camshaft Position Sensor
    By stephan in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2010, 09:38 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
