Thread: Coolant Escaping from Expansion Tank
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Coolant Escaping from Expansion Tank
    Jan 2013
    I have noticed that on a run my 2000 1.9TDI Estate is losing coolant and I discovered that it was escaping from the overflow valve that is underneath at the rear of the coolant expansion tank. At the moment I’m catching it in to a container and I poor it back in to the expansion tank when the coolant level flashes on the dashboard.
    Any suggestions please as to what could be the problem?
    I have replaced the expansion tank and the car is running perfectly but for this.
  2. Re: Coolant Escaping from Expansion Tank
    Aug 2007
    The coolant is coming out of the overflow because either.
    You have a defective cap
    You're system is being over pressurised (head gasket)
    Your new expansion tank is broken or the cap is not sealing properly on it.
    Is it a new cap as well or are you using the old one ?
  3. Re: Coolant Escaping from Expansion Tank
    Jan 2013
    Thanks for the reply.
    The cap is a new one.
  4. Re: Coolant Escaping from Expansion Tank
    Oct 2005
    Was it doing this before you replaced the expansion tank or did you replace it because it was doing this?
  5. Re: Coolant Escaping from Expansion Tank
    Jan 2013
    Do you know I can’t remember (eyes look skywards), what I do remember though is I had the old fluid flushed out as it the water/coolant looked “yucky” and because the bottle was old and had changed colour so you couldn’t see where the coolant level was.
    I ended up getting a bottle and cap from off ebay, “yes I know” but I chose a new one not used which was a compatible one for my motor.
  6. Re: Coolant Escaping from Expansion Tank
    Oct 2005
    Quote Originally Posted by whatalife View Post
    The words "compatible" and "ebay" stand out here.
    If it was my car (and I accept it's not) I'd buy a genuine new tank/cap from a reputable source - we have a few suppliers of genuine parts here on VWAF - at least then I'd be starting from a level with parts I trusted.
  7. Re: Coolant Escaping from Expansion Tank
    Jan 2013
    I'll look in to this then right away, at least one thing will be ruled out and if the problem then persists then the likelihood is the HG, bugger if it is.
  8. Re: Coolant Escaping from Expansion Tank
    Southern County Softy
    20 Post(s)
    Get a lcal garage to test the coolant system for hydrocarbons, that will tell you if HG has gone.
    I wish I could tpye...
    A4 2.5 tdi QS (mapped)
  9. Re: Coolant Escaping from Expansion Tank
    Jan 2013
    Quote Originally Posted by kite View Post
    It’s like “pisprinunciation of your worms”. Cheers by the way
  10. Re: Coolant Escaping from Expansion Tank
    Oct 2005
    Good man.
    Don't panic yet, the oil coolers are notoriously shonky. 'Yukky' coolant is the first sign.
  1. Cracked/leaking coolant expansion tank?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-07-2012, 08:56 PM
  2. Question Expansion Tank
    By m50yre in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-07-2011, 04:07 PM
  3. coolant expansion tank
    By mikeybutch in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2010, 09:02 PM
  4. How easy is it to replace coolant expansion tank?
    By Sloggs in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2009, 04:14 PM
  5. coolant expansion tank
    By remember1t in forum Golf MK2 - 1984 - 1992
    Last Post: 09-10-2007, 09:30 PM
