Thread: TPMS Questions
  1. TPMS Questions
    Jun 2006
    Hi guys,
    Over the weekend my TPMS started throwing an error in the DIS. Message was TPMS system malfunction. Tried re-initialising, if you leave the info up in the MMI it's all good. Pressures correct.
    Did a code scan earlier and got this:
    Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
    Part No SW: 4F0 910 273 A HW: 4F0 907 273
    Component: Reifendruck 3 H04 0070
    Revision: 00040070 Serial number: 00000900003078
    Coding: 0222321
    Shop #: WSC 02334 785 00200
    VCID: 214DE1B78159
    2 Faults Found:
    01470 - Rear Right Tire Pressure Sensor (G225)
    004 - No Signal/Communication - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100100
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 75
    Mileage: 84507 km
    Time Indication: 0
    Date: 2013.02.16
    Time: 18:19:48
    Freeze Frame:
    (no units): 75.0
    Voltage: 13.40 V
    (no units): 55.0
    Not Recogn.
    Not Recogn.
    Not Recogn.
    Not Recogn.
    01521 - Sensor for Tire Pressure
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 76
    Mileage: 84693 km
    Time Indication: 0
    Date: 2013.02.17
    Time: 15:38:04
    Freeze Frame:
    (no units): 51.0
    Voltage: 13.60 V
    (no units): 23.0
    Not Recogn.
    Not Recogn.
    Not Recogn.
    Not Recogn.
    Now I'm thinking it's more likely the battery in the sensor is starting to fail, it's an 05 plate and doing lots of internet searching suggests the life is between 7-10 years.
    Now, replacing them from audi is £104 each, yes I can find the same Beru sensors for less.
    However I'm not planning to put the summer tyres back on for a bit yet, and in the meantime the DIS keeps beeping loudly and displaying the error regularly (gets annoying on long journey).
    Could anyone advise on the following:
    Am I correct it's most likely the sensor(s) and not the receivors that are at fault?
    Looks like I can disable TPMS with VCDS by changing the coding as follow:
    Fourtitude.com - TPMS shut off....
    My coding is 2129443, if I subtract the 16 what would the coding become?
    Appreciate any help, don't want to break anything !!
    Andy
  2. Re: TPMS Questions
    46 Post(s)
    Hi Andy,
    Hope all is well.
    If you look at your first screen dump, the ???? in the equipment category relate to the first 4 digits of your coding so - 2129443
    If you subtract 16 from 2129 you will get 2113 so your new coding should be 2113443.
    Any coding you change will be in the Debug folder under CodingLog text file in the Ross Tech system directory.
    1 1 0
  3. Re: TPMS Questions
    Jun 2006
    Thanks Chris,
    Appreciate that, wasn't quite sure what number you subtracted the 16 from. Will give it a go and see what happens, hopefully no loud beep every few miles !!
    Thanks again.
  4. Re: TPMS Questions
    Jun 2006
    Eventually been at home long enough to get a chance to try the re-coding. Last couple of days the system had been behaving but alas it went off again today.
    Well, on recoding the beep and DIS message comes up as soon as the ignition is switched on. Figured I'd rather have a beep occasionally than every time for the next few days as have a long road trip.
    In the meantime found out that Audi want £104 each sensor, plus of course it's a tyre off job and rebalance to factor in. Can get a better deal elsewhere so will hold out.
  5. Re: TPMS Questions
    Sep 2011
    Lurking over a keyboard ...
    Hi ya Andy ...
    Your possibly also going to have to remove it from...
    Link:- Audi A6 (4F) Control Head Front (High) - Ross-Tech Wiki
    And perhaps module 19 Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Gateway J533
    Be aware the above link for CAN Gateway (module 19) says GERMAN market...
    You may have helper balloon appear or use the "Installation List" menu within module 19 and uncheck TPMS...
    Link:- Ross-Tech: VCDS Tour: Gateway Installation List
    I think the above edit in ins.cluster maybe overridden by the other codings/adaptations for TPMS...
    Hope it helps...
    ATB
    G
  1. Tpms
    By johndeere2130 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-02-2013, 03:22 PM
  2. Tpms
    By johnsimcox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-10-2012, 01:02 PM
  3. Replies: 4
    Last Post: 08-05-2012, 01:21 PM
  4. Tpms
    By Hippogriff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-02-2010, 07:16 PM
  5. TPMS.......again
    By pitch3110 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2009, 09:22 PM
