Thread: Clutch and flywheel replacement BMR engine
  1. Clutch and flywheel replacement BMR engine
    Nov 2006
    derbyshire
    Ok the, just had dpf removed and ecu remapped (passat sport 2007 ) which bumped bhp upto 240 (ish) and now the inevitable has happened. Clutch started to slip, bummer I know! Question is, clutch does need replacing but I'm wondering how much more (if any) vibration can be felt by carrying out solid flywheel conversion.
    Cheers fellas
    Sent from my GT-I9300 using Tapatalk 2
  2. Re: Clutch and flywheel replacement BMR engine
    UK Ex-pat now in Australia
    If you replace the DMF with another one then it will wear out quicker due to the additional torque - it may be worthwhile in this case to go for the solid flywheel as there is little chance of a fault developing with a solid one.
    Pedal feel and vibration would be a decision once you drive it but from others who have had it done the general opinion is that it is good/acceptable. I would also look into uprating the clutch as it will wear out again prematurely due to it not being rated for the bhp you now have.
    See if Clutch Specialists Manufacturer and Supplier of Handmade Clutch Kits are of any help.
    Had MKV GTI, Now Ford Falcon
  3. Re: Clutch and flywheel replacement BMR engine
    Aug 2011
    Meath
    Thats too many gee gees for a standard clutch, a good competition type clutch could handle it no problem
  4. Re: Clutch and flywheel replacement BMR engine
    Norfolk
    Quote Originally Posted by gresty View Post
    Cheers fellas
    Solid flywheels don't give vibration. That is just nonsense spread by people who know little. A dmf allows the engine pulses to feel slightly smoother at very low rpm (under 1000 rpm). Most performance engines use solid flywheels because a dmf would break.
  5. Re: Clutch and flywheel replacement BMR engine
    Dec 2009
    14 Post(s)
    Quote Originally Posted by martin1810 View Post
    Finally someone who understands. Thanks Martin :-):-):-).
    On previous performance cars and my last re mapped car. I used a company called Techni clutch.
    On my last turbo diesel that was mapped to around 200bhp. I used techi clutch again for a solid flywheel and uprated clutch. I think it was a stage 2 organic clutch etc.... Prepare yourself for around a £1000 bill :-(:-(.
    Hth's
    Rappy.
  6. Re: Clutch and flywheel replacement BMR engine
    Nov 2006
    derbyshire
    On some vehicles i have experienced slightly more vibration when solid fitted but was curious if any more is felt on a bmr engined vw (first experience with dmf going south on a vw) Will be doing the job myself. Just need advice now on which product would be best suited to the bhp and torque its producing (around 420 nm and 210-240 bhp) I know solid flywheel will be the way forward but 4 or 6 paddle or solid friction plate and which manufacturer? ? Been looking at valeo conversion kits?? Trying to limit the damage to the wallet aswell....................................Big car big bills big ballache!
    Thanks for advice so far
  1. Please Help Replacement engine needed BMR code 170tdi
    By Mark Redman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-07-2012, 11:49 PM
  2. Clutch & Flywheel Replacement
    By carlsbergy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2010, 04:46 PM
  3. Clutch and flywheel replacement....
    By JAY_1 in forum The Commercial Range
    Last Post: 29-09-2008, 08:19 PM
  4. clutch replacement needs new dual mass flywheel???
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2008, 10:56 AM
  5. Replacement clutch / New flywheel?
    By JasonC in forum Passat - Archive Topics
    Last Post: 20-07-2007, 11:49 PM
