Thread: "Airbag Fault!" No ODB2 fault codes??
Results 1 to 8 of 8
  1. Question "Airbag Fault!" No ODB2 fault codes??
    Dec 2009
    UK UK
    Hi all
    I have an 06 B6 Passat that is showing an "Airbag Fault!" warning. It came out of the blue one morning (i.e. I wasn't playing with the warning light!).
    I have an ODB2 scanner but that is reading no faults - is that possible with an airbag fault warning?
    Any tips - or should I take it to a dealer?
    Final question - dealer or local specialist for this sort of thing?
    Thanks to anyone with time to help.
    KP
  2. Re: "Airbag Fault!" No ODB2 fault codes??
    Aug 2011
    Meath
    Get it scanned with VCDS obd2 can miss VAG codes Ross-Tech: VCDS: DTC Comparison
  3. Re: "Airbag Fault!" No ODB2 fault codes??
    Norfolk
    OBD11 is for emissions only so it won't read airbag codes.
  4. Re: "Airbag Fault!" No ODB2 fault codes??
    Mar 2009
    York
    Chances are one of the under seat connections became loose. Disconnect the battery, check them and tighten if necessary, then find an independent with vcds to reset the warning light. Some will do it for free, others may charge a minimal amount. Don't go to.a dealer!!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  5. Re: "Airbag Fault!" No ODB2 fault codes??
    46 Post(s)
    OP where abouts are you?
  6. Re: "Airbag Fault!" No ODB2 fault codes??
    Nov 2008
    This used to happen on my wife's 53 beetle - funnily enough it wasn't the under-seat connections, but a sensor in the front bumper. Re-seating the wires solved the problem, but it was a sod to get to, I temporarily fixed it by banging the bumper with my fist (carefully!)
  7. Re: "Airbag Fault!" No ODB2 fault codes??
    Dec 2009
    UK UK
    Woking, Surrey
    Thanks for all the replies. I will take it to a local independent I use. I have always been concerned about their VCDS because they seem unable to reset my service indicator!
    Phillip
  8. Re: "Airbag Fault!" No ODB2 fault codes??
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    I had this last year, turned out to be the underseat connection, indie took it apart, cleaned connections and reset, £40.00. Deal!
  1. A6 Drivers Door Fault "Production Mode Active" ?
    By Jaset in forum VCDS - Help Requests
    Last Post: 19-01-2013, 09:06 AM
  2. A6 Avant 53 plate "Vacuum Pump" recurring fault
    By wilsongrim in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-11-2010, 09:35 PM
  3. TDI glowplug "Open Circuit" fault code
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2010, 09:14 AM
  4. Replies: 0
    Last Post: 02-04-2008, 02:14 PM
  5. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
