Thread: Parking brake fault+ESP light on - can not start the engine!
  1. Parking brake fault+ESP light on - can not start the engine!
    Feb 2013
    Sweden
    I have VW Passat, 1.9 TDI, B6 (2006) and can not start the engine anymore. "Parking brake fault" and ESP light appears on the display. However, my parking brake system works fine. I can switch it on and off.
    For the first time the same problem happened 2 weeks ago. I was driving in a highway. Parking brake fault and ESP light switched on and ECU stopped the engine. In 20 min everything was fine again.
    Four days ago the same thing happened again. However, I could not start the engine anymore. The car is in the workshop right now. They tried to do diagnostics, but could not connect to the computer via OBDII. The tool shows "Link error". They checked the diagnostic tool on another b6, it works fine. Also, they checked fuses on my B6, they are ok. They told me that the problem is probably with the ECU and I have to replaced it.
    Is there any way how to check if the ECU is causing the problem?
    Thank you in advance for your help!
    Erik
  2. Re: Parking brake fault+ESP light on - can not start the engine!
    Aug 2011
    Meath
    Get it scanned with VCDS, OBD2 isn't great on VAG cars
  1. parking brake malfunction, abs, power steering, engine light
    By frankiefee in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-01-2013, 11:50 PM
  2. ESP / Parking Brake fault (2006MY 2.4SE Avant)
    By boltona in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-01-2013, 08:01 AM
  3. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  4. Please Help Parking Brake Fault..........
    By smiggy9 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-07-2010, 11:11 AM
  5. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
