Thread: binding brakes
  1. Unhappy binding brakes
    Aug 2007
    hi everyone, i have an audi a4 1.8 t 2002, i have recently discovered a problem with my brakes, i had to brake sharply, doing this caused the brake pedal to stick down and lock the brakes on for 10 seconds or so, now i have noticed that the brakes are binding on occasionally until they cool down then they will be ok again for a week or so then the brakes bind again,when this happens the brake pedal feels hard and the brakes are very sharp too, this is happening to all 4 wheels.
    can anyone give me some idea to what might be causing this.
    any advice would be greatfull, thanks, dave
  2. Re: binding brakes
    Canada
    Hello and welcome to the site
    I don't know of your problem, search the forum there may be info for it somewhere
  3. Re: binding brakes
    Oct 2005
    Lutterworth
    From another thread:
    "Something we are starting to see is the servo on A4/Passat sticking internally due to corrosion. Have you had any issues with the plenum chamber under the windscreen filling up with water and then water getting into the car?"
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  1. binding brakes(2.3 20v coupe,1990)
    By audicoupe in forum 80 - 90
    Last Post: 29-08-2009, 10:47 PM
  2. Binding brakes, ABS Fault?
    By duffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2007, 04:08 PM
  3. brakes
    By dubliner in forum Archive posts
    Last Post: 30-05-2007, 02:00 PM
  4. Passat brakes binding????
    By Gavin78 in forum Passat - Archive Topics
    Last Post: 24-01-2007, 03:45 PM
  5. Better brakes?
    By SteveC123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-12-2006, 07:32 PM
