Thread: MMI VCDS Fault code post flood/software update
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: MMI VCDS Fault code post flood/software update
    #21
    Jan 2013
    Lincs
  2. Re: MMI VCDS Fault code post flood/software update
    #22
    Sep 2011
    Lurking over a keyboard ...
    Here's my car's module 07 adaptations cycled from 01 -200...
    Now keep an eye on the MMI screen as when I think I went past 111 the radio screens kept changing so those adaptations are irrelevant as those to me seemed related to the radio function and my belief is they are something to do the the self-tuning radio feature...
    Again use these as video for reference... use the helper balloons... anything without a balloon grab a screenshot post and ask and someone maybe able to help you...
    You may wanna start post info like what MMI kit you have in car... ie AMI, DAB, DVD sat nav, etc...
    Post PR codes? more info better people can help... even though VCDS notes changes make your own on paper...
    ATB
    G
    1 1 0
  3. Re: MMI VCDS Fault code post flood/software update
    #23
    Jan 2013
    Lincs
    Quote Originally Posted by gupsterg View Post
    ATB
    G
    Only standard (I think)..
    Colour DVD Sat Nav, CD Changer (glove box), Phone adapter in armrest. AMI and DAB on the wish list!!
  4. Re: MMI VCDS Fault code post flood/software update
    #24
    Sep 2011
    Do the PR codes from your data sticker as well and post... you can see adaptations also relate to other bits in module 07...
    The site which gets you the most PR codes will take 24hrs plus ... sometimes it can be down... Link:- http://www.woundride.com/vag/vin/
    I downloaded the data file they give on there, then opened in notepad and paste the PR code section in here Link:- http://igorweb.org/equidec/ and manually separate them with a semi-colon got me them in English...
    Here's some screenshots to ref...
    1. Download the data file...
    2. Copy the PR code section... yours maybe more or less data...
    3. Paste in this decoder, manually place semi-colons... Link:- http://igorweb.org/equidec/
    4. and here's your full factory fit PR codes ...
  5. Re: MMI VCDS Fault code post flood/software update
    #25
    Jan 2013
    Lincs
    Quote Originally Posted by DieTryin' View Post
    Anyway BT module now disconnected and a MOST bridge fitted, but MMI still a bit buggy and VCDS has given me this fault:
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 S HW: 4E0 035 729
    Component: Interfacebox H43 5150
    Revision: 00000000 Serial number: 350CW067665658
    Coding: 0001002
    Shop #: WSC 02335 785 00200
    VCID: 3365D28252D6F280ECE
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 90427 km
    Time Indication: 0
    Date: 2013.02.02
    Time: 19:01:09
    Can anyone help me on this one (the frequency is low as I cleared all faults last night)?
    Many thanks
    With many thanks to Gup and his remarkable patience, the fault is now cleared.
    The reason was although I'd deselected telephone from the list, the adaptation coding (?) still reflected the handset base in the armrest. Changed that and code gone.
    Nice one Gup
    1 1 0
  6. Re: MMI VCDS Fault code post flood/software update
    #26
    Jan 2013
    Lincs
    Cheers Gup - MMI now working (was even brave enough to activate hidden menu), and new BT module off ebay on it's way!!
    Just the glow plug to do this afternoon to see if the rough cold start is better...
  7. Re: MMI VCDS Fault code post flood/software update
    #27
    Sep 2011
    As Hannibal would say "Luv it when a plan comes together!"... .......
  1. MMI 2G High 5570 Software Update Discs
    By A6al in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2012, 12:38 PM
  2. MMI 3G Software Update
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2012, 03:14 PM
  3. MMI Software update?
    By Yowfailed in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-02-2012, 08:13 PM
  4. VCDS faults before MMI update
    By piotrek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-04-2011, 01:13 PM
  5. Concert radio software update without MMI
    By ktulu in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-09-2008, 10:00 PM
