Thread: Passat B6 1.9tdi Steering column defective
  1. Passat B6 1.9tdi Steering column defective
    May 2012
    Manchester
    9 Post(s)
    Hi Guys,
    I have just started up my car today and got a "Steering Column Defective" warning. Take to workshop. The car starts and drives fine but there is a red steering wheel lit up on the dashboard. I did a VCDS scan and some errors came up. I cleared the errors and it now works fine. But I am a little worried as I have heard the engines can just cut out and turn off while driving??
    Below is a complete VCDS scan of the errors. Any help will be greatly appreciated. (Note my car is a 1.9TDI)
    Sunday,03,February,2013,11:20:17:37412
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ6P082682 Mileage: 143160km/88955miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 DP HW: 028 101 274 2
    Component: R4 1,9L EDC G000SG 7870
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000071
    Shop #: WSC 00490 210 84728
    VCID: 70E5A16463B80CE
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0658178185
    Coding: 0013569
    Shop #: WSC 00028 028 00001
    VCID: 2F676218BE06536
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 DF
    Component: Climatic PQ35 090 0505
    Shop #: WSC 00000 000 00000
    VCID: 6BDFB6084A9EEF6
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000003521036
    Coding: A0880F0700041A00000000000F000000000959435C0000
    VCID: 2E597F1CB90C5AE
    Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer VW461 012 0503
    Coding: 00065493
    Shop #: WSC 00028
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 186
    Mileage: 142704 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 8.55 V
    OFF
    ON
    ON
    ON
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 F HW: 3C0 909 605 F
    Component: 02 AIRBAG VW8 029 2421
    Revision: 08029000 Serial number: 0039USGKKM0J
    Coding: 0012338
    VCID: 29538C0080E23D6
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenksäulenmodul 005 0010
    Revision: 00005000 Serial number: 3C5953507C
    Coding: 0000013
    VCID: 2A51730C85E436E
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 H HW: 3C0 920 960 H
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0014000 Serial number: 00000000000000
    Coding: 0005405
    Shop #: WSC 00712 210 10546
    VCID: 285589049BE804E
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C059190548
    Coding: 3DFD2C04C21003
    VCID: 21439420F8D2F56
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 H HW: 3C0 959 433 H
    Component: IMMO 038 0364
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 00712 210 88117
    Part No: 3C0 905 861 C
    Component: ELV 023 0350
    3C0905861C ELV 023 0350
    1 Fault Found:
    02818 - Steering Column Lock; Enabling for Electronic Ignition Lock
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 203
    Mileage: 143162 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:09:16
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2366
    Coding: 0000693
    VCID: 3669577C415C62E
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    VCID: 336F6E68522E776
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 038 0453
    Coding: 00910A0801864E763804941D70085FCE103C80
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Component: Innenraumueberw.002 0508
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000692
    VCID: 37775A7846569B6
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
    Component: EPB VD8HC005 013 0005
    Revision: 013
    Coding: 0000011
    VCID: 2649873C91FC12E
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 143088 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:35:43
    Freeze Frame:
    Voltage: 11.59 V
    Count: 202
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 195 B
    Component: Radio BVX 008 0015
    Coding: 0040400
    VCID: 254B8030ECFA196
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    VCID: 346D6D74572070E
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5B7810B40A216
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
  2. Re: Passat B6 1.9tdi Steering column defective
    May 2012
    Manchester
    9 Post(s)
    ok guys an update. just tried to start it again and the error came back. the engine also cut off. after trying a few goes it started again. and now the message visit work shop steering column defective intermittently shows. sometimes it starts fine and sometimes it displays the error.
    help guys? im starting to get very worried im in for a costly bill here.
    thanks
  3. Re: Passat B6 1.9tdi Steering column defective
    UK Ex-pat now in Australia
    You probably need a new electronic ignition lock unit which goes on the steering column and you may need a new central electrics control module to pair with it.
    It used to be a whole column was replaced but i believe just the lock can be replaced now.
    It is quite a common problem on B6's. Depending on the year and mileage of your car it may be worth seeing if a VW dealer can submit a goodwill claim for it - you will need it diagnosed properly 1st though by them.
    Had MKV GTI, Now Ford Falcon
  4. Re: Passat B6 1.9tdi Steering column defective
    Norfolk
    Quote Originally Posted by k114l3d View Post
    thanks
    It's explained here: B6 STEERING FAULT - PASSAT
    Dealer fix is about £350. They just need to change the steering column lock and recode usually. The lock won't engage when you are driving so the car is safe to drive.
  5. Re: Passat B6 1.9tdi Steering column defective
    May 2010
    Bolton UK
    thanks
    Did you get this fixed? And what was the ££damage?
  1. Steering Lock column Defective !!!
    By PDL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-05-2015, 08:25 AM
  2. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  3. Please Help Steering column lock defective!
    By the surfer in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-02-2010, 12:45 PM
  4. Question Steering Lock column Defective
    By tobetrue123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-12-2009, 07:18 PM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
