Thread: cruise control
Results 1 to 10 of 12
  1. cruise control
    Jan 2013
    Preston UK
    new A6 avant picked up yesterday, thrilled with it but.......
    cruise control not working, the button on the end of the stalk is jammed - hopefully an easy fix on Monday morning
  2. Re: cruise control
    Wuffles Guest
    You've presumably pulled the stalk forward to engage it first right? I hate myself for even asking, sorry.
    On the other hand, it could be borked as I've had my cruise die on me once too, so I know it can happen.
  3. Re: cruise control
    Southern County Softy
    20 Post(s)
    If its a manual box it could be a failed switch on the clutch pedal
    I wish I could tpye...
    A4 2.5 tdi QS (mapped)
  4. Re: cruise control
    Jan 2013
    Preston UK
    thx, yes pulled it , moved it up and down. . . the button on end of stalk moves again now but I think switch is dead.
    its a multitronic, always ok on last A6
  5. Re: cruise control
    46 Post(s)
    Multitronic lol.
    Make sure you're doing at least 19mph for the cruise to enable. Put it in the position where you can adjust the speed, it's on standby in this position.
    Now drive up to around 30mph and press the little button, it should enable.
    Sent from my iPhone using Tapatalk 2
  6. Re: cruise control
    46 Post(s)
    Also if you adjust the speed on the stalk you should see a display appear on your DIS telling you the cruise speed.
  7. Re: cruise control
    Jan 2013
    Preston UK
    tried it at 30 and mainly wanted to set it to keep at 50 in motorway roadworks with average speed cameras. . . I just don't think the button is operating to turn it on
  8. Re: cruise control
    jbanfie Guest
    Interesting, my push button at the end of the stalk is also faulty and, reading the fault codes, the car realises it (improbable signal) and shuts down the cruise control.
    I'm very impressed with the fault management systems in VW/Audi cars, basically it tells you what's wrong and you just change the part (or they do under warranty!)
    Mine is intermittent, so I'm waiting till the weather improves a bit so the car doesn't get dirty too quick after they wash it for me!
  9. Re: cruise control
    Jan 2013
    Preston UK
    pretty similar,
    lol people at work accuse me of "getting something checked under warranty" just to get car cleaned
  10. Re: cruise control
    46 Post(s)
    Don't get the car washed by them, no care at all is given and you could end up with those little pesky swirl marks
  1. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  2. Question Cruise control
    By JayA3sline in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-12-2010, 12:43 PM
  3. Question Cruise control button but no Cruise control
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2010, 10:34 AM
  4. Instalation of cruise control-does existing control modul support it?
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2009, 09:42 PM
  5. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
