Thread: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
Results 1 to 10 of 36
  1. b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi all, just picked up the above y reg January '01 b6 1.8 turbo 150.
    The car is generally is cracking order with just a couple of tiny scratches etc which should vanish when properly polished and waxed.
    The only niggle is that the temp gauge is only getting to around 65/70 and the heater is blowing cold.
    When I collected the car 1 week ago the seller showed me bills etc for cam belt/water pump at around 25,000 miles and 2 years ago, so I felt that they are not imminent jobs.
    He went on to explain that since he was given a newer car the Audi was parked for a couple of months and when he started it before Christmas the temp gauge was not rising to 90 at normal running temperature.
    He was advised that he had a coolant temp sensor playing up so replaced it to no improvement, so went on to change the thermostat (£60 part)
    This morning after a week of use and being bloody cold each day I decided to have a bit of a look about, so having read a few similar threads here on the forum this is the score so far;
    Started car from cold and with coolant level checked and good
    Allowed car to sit and idle for about 20 minutes
    Altered heater controls in all positions, up/down, max cold to max hot etc and all flaps seem to be moving air about correctly
    Gauge still at 70
    Under bonnet
    Top rad hose hot
    Water pipes coming from what I think is the oil filter housing, hot
    Bottom rad hose cold
    Cant see hoses going to heater matrix, so don't know what they are doing.
    Got the hump and thought I might nip up the village to my mates garage and see if he was able to shed any light on things or check anything for me.
    Garage was closed, so turned around but noticed temp gauge climbing for the first time and assumed that there had been an air lock which I had cleared while squeezing hoses etc.
    Got back onto my driveway and sat playing with the heater controls waiting for a sudden burst of heat to confirm my success.
    The gauge started to drop back down to 70 and the air still cold.
    Revved the engine to around 2.5/3000 rpm and heat started to come through the vents but turned cold immediately that I came off the throttle
    Am I to think that the water pump is dud and just spinning on its shaft, and possibly replaced with a cheapo at the last occasion, or that the thermostat is a cheapo e-bay jobby, and that all he told is lies
    I am thinking that I should ignore everything he said and start afresh from the beginning but I can't just throw money about pointlessly
    Who has had this issue and what was the actual cure
    January 2001
    Audi A4 B6 1.8 TURBO 150 AVJ engine code , 5 speed manual with 91,000 miles
    The car drives and runs superbly, if a little slow at starting from cold.
    Many thanks in anticipation
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  2. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Southern County Softy
    20 Post(s)
    It sounds like a failed stat to me.
    I wish I could tpye...
    A4 2.5 tdi QS (mapped)
  3. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Oct 2009
    10 Post(s)
    Yes it does but he said it was new, does £60 just for the part sound right, he said the stat comes in its' own housing.
    Just being reading on Audizine, would a clogged matrix/core cause the temp gauge to play like this
  4. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    20 Post(s)
    I think a failed waterpump would cause overheating.
  5. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Oct 2009
    10 Post(s)
    Yep, agreed and I think the stat does work and that I must a flow restriction. Reading some of Crashers' replies to similar threads the matrix clogging is common on this model so I'll have another look in the morning as I now know the location of the pipes is not where I had been looking and that they are a doddle to access
    Thank you friend
    Stuart
  6. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Oct 2009
    10 Post(s)
    Flushed my heater core with CLR. Lots of pics.
    can anyone confirm which of the two pipes is the "in" and which is the "out", reading the link above with pictures I assume that the bottom hose is the "in" and the top is "out", can anyone confirm this ?
    Stuart
  7. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Oct 2009
    10 Post(s)
    Well, didn't get the matrix sorted or cleaned out yet but as there was not any water at the pipes anyway, I'm going for the thermostat and ignoring what the fibbing sod told me.
    As I'm lead to understand that this engines' stat and apparently many others these days, comes in its' own housing would anybody on here have access to a diagram or picture of what this thing looks like and where it's positioned and whether I'll need any special tools or tricks to change it.
    Obviously drain fluid swap unit refill fluid , but are there any little tricks to bleeding the system, ie; cold engine, hot engine, car upside down and back to front,.you get the picture.
    Any pictures and tips gratefully received, and does £60 sound right, alternatively could it be just the old fashioned £10 thermostat like most old cars?
    1.8 turbo AVJ, 5 speed manual in a B6, January 2001
    Many thanks
    Stuart
  8. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Aug 2011
    Meath
  9. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    20 Post(s)
    Well done Stu.
    Sent from my GT-I9305 using Tapatalk 2
  10. Re: b6,1.8t AVJ,5 SPEED MANUAL COOLANT/HEATER ISSUE
    Mar 2011
    Kendal Cumbria UK
    Glad its sorted mate, amazing such a small sensor can **** everything up so much! shame they didn't program the ecu to use the other sensors as a backup system...!
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  1. A6 1.9 TDI 5 speed manual gearbox
    By MitchW in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2012, 06:10 PM
  2. I need a recon 6 speed manual box
    By A6SE in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2011, 02:39 PM
  3. 6 speed manual gearbox noise
    By paul.mgrath in forum Golf MK6 - 2009 - 2013
    Last Post: 25-05-2010, 09:07 PM
  4. Coolant leak / heater issue
    By Steve2.7T in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-12-2009, 12:03 AM
  5. 5 speed to 6 speed manual box - when?
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-03-2009, 08:11 PM
