Thread: 2.0 tdi dsg 6 spd free wheel
  1. 2.0 tdi dsg 6 spd free wheel
    Aug 2008
    Does anyone know if the 6speed DSG gearbox fitted to the 2.0tdi engine has the "freewheel function",
    as mentioned on a VW website quote "In the zero-load state (foot off the accelerator) the clutch is automatically disengaged and the engine is held at idling speed."
    It is not clear if its only fitted to certain engine/gearbox combinations??
    Guy
    2.0tdi GT DSG, Pacific Blue, Vienna "Shetland" leather sports seats, Discover Pro Nav system, Colour multifunction display, 2-zone Climate control, steel door sill trims, Rear chrome strip
  2. Re: 2.0 tdi dsg 6 spd free wheel
    Mar 2008
    I have just been reading an article about this in the Audi Driver Magazine and in the case of the new Audi A3 you have to have Drive Select and select the Efficiency mode. I am assuming that on the new Golf VII Drive Select is called Driver Profile Selection. If so it is standard on the SE and GT models. This is mentioned in the DSG section of the Owners Manual that has already been posted in an earlier mode - page 176 Driving with an automatic gearbox.
  3. Re: 2.0 tdi dsg 6 spd free wheel
    Nov 2009
    46 Post(s)
    Why not just knock the lever into N?
  4. Re: 2.0 tdi dsg 6 spd free wheel
    Mar 2008
    Yes but the DSG software does a bit more than just engage neutral. While the car is freewheeling the geabox control unit pre-selects the gear which is suited to the speed at which the car is moving. This means that, as soon as the control unit tells the clutch plates to press together, the car is in the right gear for the speed it is travelling. It also ensures certain parameters are met before it will allow freewheeling such as a minimum speed of 12mph, the accelerator pedal must be in the rest position and the downhill gradient must be less than 8%. The freewheeling will stop automatically as soon as the brake pedal is used, the downhill gradient is greater than 15% and when the vehicle is travelling downhill, it achieves a speed faster than the cruise control system's set speed.
  1. 2.0CR TDi B7 Manual Vs B7 DSG Vs B6 DSG
    By logiclee in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 20-04-2011, 05:13 PM
  2. Question R36 DSG wheel into 58plate Highline DSG
    By CocoPops in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-03-2011, 07:56 PM
  3. Retrofit DSG wheel
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 09-07-2010, 08:07 PM
  4. 50k miles 2.0 TDI dsg S-line or 25k (non S-line spec) DSG tdi???
    By Duncsharp in forum Audi A3 - Archive Topics
    Last Post: 12-02-2009, 03:33 PM
  5. Question Is this gear oil the correct type for a manual 6-spd TDI?
    By the surfer in forum Golf MK5 - 2004 - 2009
    Last Post: 03-11-2008, 03:17 PM
