Thread: Coolant leak on 1.9tdi
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Coolant leak on 1.9tdi
    Mar 2011
    newtownards
    Yes peter thats the very one. So am I right in saying the front has to be put in service position
  2. Re: Coolant leak on 1.9tdi
    Aug 2011
    Meath
    If the under-shield is fitted you need to remove it, As Peter said the air-con pump is in the way when you move it out of the way starter is easily accessible. These cars ae easy to work on once you get into the zone
  3. Re: Coolant leak on 1.9tdi
    Mar 2009
    I have a similar problem to greenkeeper where I have a leak from the core plug above the starter motor.
    It's a 1999 1.9TDi avant AFN engine.
    I have a few questions.
    Assuming I can actually get into this area with my car on ramps in the driveway, could anyone provide advice on removing and fitting please?
    To remove, I've seen several articles talking of drilling / screwing it out.
    To replace it, I've read pieces saying it's a tap in with a drift, and others mentioning gasket sealant so any tips appreciated.
    Are there any more plugs I should be aware of as I'd maybe check them as well?
    Thanks in advance,
    Grant
  1. Coolant Leak
    By Fishdockroad in forum Golf MK6 - 2009 - 2013
    Last Post: 21-10-2013, 12:09 PM
  2. Tracking down a coolant leak on a Mk5 1.9TDI > where to start?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-11-2012, 12:01 PM
  3. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  4. Replies: 1
    Last Post: 18-10-2007, 11:26 PM
  5. 1.9TDi Coolant Water Leak Rear of Engine - Advice Please
    By delta925 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2007, 11:23 PM
