Thread: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
Results 1 to 8 of 8
  1. Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Nov 2011
    Duns Scotland
    11 Post(s)
    I need to remove all 4 ABS sensors to clean and re-install. Maint manual makes it look easy but any tips/guidance would be appreciated. Are they likely to be seized? I intend to just pull them out, clean and re-install without renewing the sleeves.
    Thanks in advance.
  2. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Nov 2011
    Duns Scotland
    11 Post(s)
    Can't believe no one out there has removed the ABS sensors. A reply to the effect it is straightforward if indeed it is would be appreciated!
    Thanks in anticipation.
  3. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Aug 2008
    Isle of Skye
    Quote Originally Posted by ceilidhalfie View Post
    Hello, I have removed and replaced numerous ABS sensors on various cars including my 2001 allroad and my 2003 RS6. I have had problems 2 times, firstly the bolt (normally allen head) that secures the sensor to the hub can be corroded away which can be difficult to deal with. I always replace this bolt with a stainless steel bolt and use copaslip on it. The second (and much worse) problem I had was the sensor itself seized in to the hub. The sensors are fairly robust, but not tough enough to take the force of stilsons or pliers to remove without damaging them. In my case the sensor was completely seized (this was on a 20 year old Saab 900 by the way) and I had to cut the wire to the sensor, then drill a hole in it to pry it out with a screwdriver. I obviuosly had to buy and replace the sensor! NOTE: I also always put copaslip on the sensor when I put them back which makes future removal simple. Hope this helps!
  4. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Nov 2011
    Duns Scotland
    11 Post(s)
    Thanks for that skyegtb. I guess I will soak overnight with some WD40 (as I do with the brake bleed nipples before changing the brake fluid) and try the next day. On replacing I will coat with the anti-corrosion grease I use on my Mercury outboard. VCDS is showing a temporary ABS fault code which, from another forum, looks, like dirty sensors. Your info was what I needed. Many thanks.
  5. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Mar 2008
    High Wycombe
    Give us a chance! it's only been 3 days! (and some of us missed your first post)
    I've removed the front ones. No WD40 or anything, they just pulled straight out with a bit of levering (I used a thin spanner to lever on both sides). There was no bolt holding them in, just friction on the sleeve (a sort of sprung bit of metal). I just wiped off the dirt, put them back in with the original sleeves.
    The only thing I couldn't find any reference to was whether the gap between the sensor and the abs ring needed setting, so I just tapped them in until they stopped when the touched the ring. I figured that the ring would knock them back out a bit or wear them off to fit. They've done 20,000 miles since then with no problems.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  6. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by NickPicks View Post
    Many thanks Nick for your input. The manual states the clamping sleeve pushes all the way in the abs hole until it stops, then simpy insert the sensor with sealing collar as far as it will go. As it seems to work, like you I will not renew the clamping sleeves (as the manual recommends).
    Thanks again - did not mean to be pushy for a reply. I guessed my posted must have slipped past everyone.
  7. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Mar 2008
    High Wycombe
    You found more in the manual than I did then. I don't know how much the sleeves cost, but they can't be very much - I just needed the car to be working that day.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: Removing & Replacing ABS Sensors 2002 Allroad 2.5 Auto AKE
    Jun 2008
    Lichfield, Staffordshire
    Just hijacking this thread, where are the connectors down to the ABS sensors? they must be deep in the engine bay or under the plastic inner wheel arch. It's raining so I don't want to grovel round under the car...
    cheers
  1. Changing ATF & Filter on 2002 150Kmiles AKE Allroad 2.5 TDI Tiptronic
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-07-2012, 07:52 AM
  2. Replacing O-Ring for Oil Level/Temp Sensor on 2002 Audi Allroad 2.5 TDI Automatic AKE
    Last Post: 12-04-2012, 05:25 PM
  3. Cleaning Cam Belt & Auxiliary belt areas on 2002 Audi Allroad 2.5 TDI Automatic AKE
    Last Post: 19-03-2012, 05:59 PM
  4. 2002 Allroad 2.5TDi AKE - removing caps on glow plugs
    Last Post: 15-12-2011, 02:02 PM
  5. Replacing Timing Belt on allroad 2.5 TDi AKE 2002
    Last Post: 29-11-2011, 09:53 AM
