Thread: Revs dropping
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Question Revs dropping
    Dec 2011
    Hull, UK
    Hi all had to replace my battery today after TVs just dropped and died in traffic. Had the battery tested and it was curtains for the battery.
    since then I have noticed that when coasting the revs drop done to around 500rpm and then rise quickly back to around 800rpm which is normal idle.
    is this an issue or indicative of an impending issue?
    thanks
    chris
  2. Re: Revs dropping
    Dec 2011
    Hull, UK
    Some more info - just checked battery with a multimeter
    Battery 12.6v
    Running engine 14.1v
    Full beam on 14v
    FUll beam and heater on 13.9v
    Fb heater demist 12.5v
    All on at 2000rpm 13.8v
  3. Re: Revs dropping
    Aug 2011
    Meath
    VCDS scan needed
  4. Re: Revs dropping
    Dec 2011
    Hull, UK
    Thanks doctle, but I won't get chance to get it in til at least the weekend. Is there anything I could try or look at in the meantime?
  5. Re: Revs dropping
    Aug 2011
    Meath
    Check all vacuum hoses are tight and the air filter is clean. There's not much more you can do until it's scanned, is the temperature sitting at 90?
  6. Re: Revs dropping
    Dec 2011
    Hull, UK
    It may well be, it's only started doing it since battery issue
  7. Re: Revs dropping
    Dec 2011
    Hull, UK
    Quote Originally Posted by Doctle Odd View Post
    Temp not sat at 90
  8. Re: Revs dropping
    Aug 2011
    Meath
    It needs a scan to eliminate the CTS
  9. Re: Revs dropping
    Dec 2011
    Hull, UK
    Err at the risk of sounding daft.......CTS?
    thanks doctle
  10. Re: Revs dropping
    46 Post(s)
    Coolant temperature sensor I think?
    Happily to be corrected though!
    Sent from my iPad using Tapatalk HD
  1. Losing revs when dropping clutch
    By baby-mechanic in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2010, 11:46 AM
  2. Replies: 7
    Last Post: 29-11-2009, 10:25 AM
  3. revs dropping
    By mbjoyce in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2009, 08:11 PM
  4. revs dropping when dipping the clutch
    By uplink1001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-12-2007, 11:05 AM
  5. mk3 dropping in revs
    By aharrod in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2007, 12:07 PM
