Thread: Tie end rods and C links front axle replacement
  1. Tie end rods and C links front axle replacement
    Dec 2011
    leeds
    Hi All
    I recently had the control arms changed on my B7 S line - all good so far.
    I'm looking to change primarily the C links or sway bar link as they are called I think and possibly the tie end rods.
    Couple of questions.
    1. Are the C link easy to change, I took the wheel off and can see them and to be honest it looks as though one has a nut missing!!
    2. Are the tie end rods easy to change and what should I look out for?
    3. Will I need a wheel alignment after changing c link, tie end rods or both?
    4. What make/brand is good as i'm keeping the car for a few years.
  2. Re: Tie end rods and C links front axle replacement
    Aug 2011
    Meath
    Buy genuine parts they're not that expensive, you will need to have the car tracked after changing the tie rods. I think you have to torque the "C" links with the wheels on the ground (or maybe off the ground)
  1. Question Tie rod replacement
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2012, 08:23 PM
  2. Tie rod end adjustment screw
    By andrewaudi in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2011, 01:12 PM
  3. How To Front anti roll bar drop link rods
    By vw_craig in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2011, 05:43 PM
  4. Front end alignment after timing belt replacement
    By fasttdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2008, 05:50 PM
  5. tie rod end
    By V6quattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-03-2007, 08:05 PM
