Thread: audi 80 tdi flat-spot/judder at 2k and puff of smoke
  1. Question audi 80 tdi flat-spot/judder at 2k and puff of smoke
    Aug 2007
    my audi 80 1.9 tdi 1Z engine seems to developed a new problem the last few days. at 2k to 2.2k revs usualy in 4th or 5th gear the car wont accelrate any more, after a few seconds there is alot of smoke and then she will accelerate further. what is causing this?
    is it the injectors and injector pump?
  2. Re: audi 80 tdi flat-spot/judder at 2k and puff of smoke
    lamondi Guest
    Hi, i have the same problem with the same engine, i have checked all the pipes around the turbo area, they are fine, i have replaced the fuel filter & checked all fuel lines no problems there, i changed the oil & filter & you guessed it no change, my fault is intermittent & 2 days ago the instrument cluster (rev counter, speedo, fuel gauge, temp & dashboard lights) failed but the car seemed to run better?? i checked the fusebox & fuse 12 had blown, i replaced it with another 15 amp & the dashboard sprang back into life until i put the car into reverse & the fuse blew again!!! after reading for symptons on this site i removed the trunking around the left hand hinge of the tailgate & found 6 out of 10 wires were completly knackered, i spliced them back, replaced the fuse, put it in reverse & it worked a treat. i then did 120mile round trip & the car ran a lot better, there is still a slight flatspot after changing gear but i would say it's 70 percent better. also i have been using shell V power for the last 4 tankfulls & this has immproved the performance noticeably. if by the time you read this you have solved the problem, please let me know how you did this. Cheers
  3. Re: audi 80 tdi flat-spot/judder at 2k and puff of smoke
    Dec 2007
    8 Post(s)
    Quote Originally Posted by rh-keith View Post
    The first thing to check is the short rubber hose that connects to the inlet pipe on top of the turbo unit. This hose can develop
    a split underneath it causing poor running conditions
  4. Re: audi 80 tdi flat-spot/judder at 2k and puff of smoke
    lamondi Guest
    Hi again, disconect the vaccum pipe that pushes onto the egr valve & should sort it, it did for me.
  1. V6 Tdi intermitent flat spot/surge
    By CherryB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2007, 12:25 PM
  2. Intermittent Flat spot
    By scoobystu in forum The Commercial Range
    Last Post: 27-08-2007, 04:07 PM
  3. 2k Bora - Engine Flat Spot
    By Cam in forum Bora - 1998 - 2005
    Last Post: 04-03-2007, 04:56 PM
  4. tdi prob flat spot and air in fuel(help)
    By wedge in forum 80 - 90
    Last Post: 13-02-2007, 02:22 AM
  5. TDi Flat spot...
    By chrisp in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-01-2007, 12:02 PM
