Thread: A6 flywheel question
  1. A6 flywheel question
    Hi, Newbie here, hello to all the guru's out there! I have a question that I hope you can answer for me. I have an '07 A6 SE with a 2.0 TDI BRE engine and Multitronic 'box, bought recently. Runs well apart from down a bit on top end power and mpg not so good, 39mpg over a trip to Liverpool and back from Hampshire, not good but this can be improved though. But, when starting everything is normal and ok, however, with a warm/hot engine, there is a quite pronounced rattle. This is not a rattle like two bits of heat shield or something, it's heavier than that. I asked my local Indie what it was and he told me that it was the DMF, when I then took the car back to where I bought it, (not a VW/Audi specialist), the service manager said that this car didn't have a DMF! Although I put more faith in what my Indie tells me, did this car come with a DMF or not? I have looked but can't find anywhere on the net that helps me here, so please if anyone has a definitive answer, please let me know.
    Trumpet
  2. Re: A6 flywheel question
    Sep 2011
    Lurking over a keyboard ...
    YEP has DMF... ref page 7 here link:- Variable Automatic Transmission multitronic® 01J
    Also google for ssp 01J ...
  3. Re: A6 flywheel question
    131 Post(s)
    1976 Post(s)
    Technical product information Transaction No.: 2018499/7
    Metallic rattling noise from gearbox at start - A4 and A6 2.0l TDI with Multitronic
    Release date: 22-Feb-2010
    Customer statement / workshop findings
    Metallic rattling noise can be heard from the gearbox bell housing while starting the engine.
    Technical background
    Two-mass flywheel incorrect.
    Production change
    Measure
    Try to follow up the customer's complaint (according to the customer's description/technical background), in order to establish whether it can clearly be allocated to this TPI. Only carry out the following repair if all the given criteria (model/type, chassis number, engine/gearbox code, PR number(s), parts numbers, software status, coding) correspond exactly. Otherwise this solution will not resolve the problem and will possibly result in further repairs. In this case, we reserve the right to refuse settlement under warranty and will back bill the parts which have been removed. If the above problem is confirmed, the dual-mass flywheel must be replaced as described in the workshop manual. To avoid repeating the repair, the following points must be observed:
    Check whether there are adapter sleeves for centring the engine/gearbox in the cylinder block. Use if necessary
    Play at the clutch shaft is less than 0.3 mm
    Thrust bearing play of the crankshaft is less than 0.45 mm
    Intermediate panel between the engine and the gearbox should not be or become squeezed
    1 1 0
  4. Re: A6 flywheel question
    Not quite true Gupsterg. The Manual has a DMF but the Multitronic has a damper quite different to a DM in the flywheel which is a sevicable item. Does it rattle at idle. Inform the dealer in writting that you have a seriuos fault and request they remedy the fault. Regards Peter
  5. Re: A6 flywheel question
    Sep 2011
    Because four-cylinder engines do not run as smoothly as six-cylinder engines, a dual-mass flywheel is used in four-cylinder engines.
    I think OP got a 2.0 TDi four cylinder, I was only going by that and the SSP ...
    Quote Originally Posted by a8 tech View Post
    if the noise is a clatter then it suggests the dual mass flywheel (mulititronic has this as well as the manual transmission)
  6. Re: A6 flywheel question
    Thank you to all, you have given me lots to go on, I'll keep you informed as to how things pan out.
    Vielen Dank!
    Trumpet
  7. Re: A6 flywheel question
    Sep 2011
    Another interesting read concerning the changes Audi did to multitronic from 6 to 7 plates Link:- MOTOR Magazine Article | MOTOR Information Systems
  1. Flywheel
    By acebundi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-04-2011, 01:47 PM
  2. Flywheel
    By giedwards in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2010, 05:55 PM
  3. Question Flywheel Or Not????
    By MATTYBOY C in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-12-2008, 12:53 PM
  4. Which Flywheel?
    By dod1e in forum Golf MK5 - 2004 - 2009
    Last Post: 18-09-2008, 08:25 AM
  5. Flywheel
    By BEAST O BODMIN in forum Chat - Anything with wheels
    Last Post: 15-03-2008, 02:07 PM
