Thread: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
Results 1 to 10 of 17
  1. A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Dec 2011
    uk
    can any one help my A6 has just started juddering between 1000 and 2000 rpm when accelerating at low speed just like its not runnig on all cylinders
    also my adaptive headlight warning light has come on i think this is refering to the self leveling system wich seems to be working any help would be appreciated
  2. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Sep 2011
    Lurking over a keyboard ...
    Two things spring to mind... but before that....
    When was last service? have you had air/fuel filter done?
  3. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Dec 2011
    uk
    it was serviced about 5000 miles ago air and fuel filter where replaced
  4. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Sep 2011
    Without a VCDS scan / diagnostics scan... my best two guesses due to it being an early 3.0 TDi...
    i) injectors ii) gearbox oil update & software required... one or the other... could be both ...
    Is yours an Auto?
  5. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Dec 2011
    uk
    yes it is an auto
  6. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Sep 2011
    So I'm guessing you not got VCDS? not a have a diags scan/log to go by? as you would have posted if have?
  7. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Dec 2011
    uk
    i have a code scanner but it is not showing any errors
    i have just recalled that the problem started when i filled the car up from nearly empty
  8. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Sep 2011
    You can visually check your injector P/N and revision... remove the engine cover... then check the plastic collar...
    This image... Audi P/N is 059130 277BD.... just below Audi P/N 110117 which is 17/01/11... the Bosch P/N is last line 0445115 079...
    You are not having very bad white smoke?
    do not confuse with milder vapour from low temps at moment... it will be dense, smell bad if unburnt diesel...
    You can also visually check the plate on your gearbox to see the serial number... car will need to be raised to view plate...
    Ref this thread Link:- ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
    Your code scanner is not going to allow measuring block testing like on VCDS (Ross Tech) or VAS (dealer diags)...
    Link:- audi 3.0tdi engine measurement blocks
    Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Transmission Control Unit J217
    You could ask a member close to you to scan your car Link:- VWAF User Location Map - VCDS - Google Maps
    Member equal beer tokens... you could go to a forum sponsor garage near you Link:- Site Sponsors - Directory Of Site Sponsors
    VCDS scan@indi gonna be half what Audi dealer charge for diags... with VCDS scan you will also get part no/revisions for car modules...
    Without scans I've told you the worst two... in my early ownership of my 3.0 TDi I let fuel run low but not empty that could not reach garage never an issue and I've had a few ...
    Will keep an eye on updates to thread but at mo no more info to add ... maybe another member with another idea will come along ...
    ATB
    Gup
  9. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Jun 2012
    UK, UAE
    Does the headlight error only appear on start-up when light switch is in AUTO? or is it on every start-up or only when the headlights are switched on?
    WIth regards to the judder - my car has that issue at present and Audi have advised a gearbox fluid change (to a newer fluid) and a software update to cure it.
    Six.
  10. Re: A6 3.0 TDI quattro 04 juddering between 1000 and 2000 rpm
    Apr 2012
    Northumberland
    Not guaranteed to be a cure, but a good old fashioned booting might help. Unless of course you drive like a hooligan to start with....
    if you are always pottering about in town a good clean out may be in order.
    nothing to lose other than some fuel....
    cant help with the headlamps.....
  1. Question A4 130 TDI making sucking noise between gear change and from 1000-2000 rpm??
    By giggsy07 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2011, 01:48 PM
  2. strange knocking rattle at 1000 to 2000 revs tdi 110
    By mjrplan9 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-10-2010, 02:16 PM
  3. Engine Lumpy between 1000 and 2000 RPM
    By BIGMAN1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-04-2010, 09:56 AM
  4. GT TDI 150 Turbo whistling at 1500 - 2000 RPM
    By Buzzlightyear_2 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-07-2008, 02:22 PM
  5. Replies: 1
    Last Post: 05-12-2007, 09:58 PM
